75' horn question
Old May 27, 2009 | 10:14 PM
Pete's75's Avatar
Pete's75
Cruising
Default 75' horn question
My 75 is missing the horn on the driver side and I'm wondering if anyone can tell me which horn is the high note and which is the low note? Are the horns marked indicated the high or low? I'm planning on looking for a replacement at some summer swap meets so this information would be helpful. Thanks.
Old May 28, 2009 | 02:32 AM
RunningMan373's Avatar
RunningMan373
As far as i know, Corvettes only came with one horn. I added two, a high and a low, when my original ca-daped out.
Old May 28, 2009 | 11:44 AM
Pete's75's Avatar
Pete's75
Cruising
In my assembly manual, it shows two horns, and the connection is there for it.
Old May 28, 2009 | 11:50 AM
...Roger...'s Avatar
...Roger...
Dual horns were an option. The notes are marked on the horns,but I have no idea which note is high or low. Musicians ?
Old May 28, 2009 | 11:57 AM
CCrane65's Avatar
CCrane65
From 1971 to 1974 there was only one horn, the rest had two.
For 1975, the low note part number is 9000049 and the high note was 9000038.
cc
Correction, the first design 1974 had one horn the second design had 2. Same numbers as the 1975.
To 75' horn question
