steering box
If your car came with power steering, then you probably ought to fit a power steering box. Borgeson makes one with a 12.7:1 ratio, but unlike your standard 16:1 box, the Borgeson has internal power assist. What's more, it has a R&P control valve on the input shaft of the box, which is more sensitive to demand, and it has variable ratio power assist.
In other words, driving straight ahead, there is almost zero assist, but the further you turn the wheel, say when parking, the greater the power assist. Just like in a modern car. If you go this way, you can use your factory pump, but you will need two new hoses, pressure and return, to connect to the box.
You will have to replace the power control valve on the relay rod with a drag link adapter. You use your own Pitman arm and you can ditch the power ram and the hoses. All the bits you need are at www.borgeson.com and it's a relatively simple fix that will make a world of difference to the way your car drives.
Regards from Down Under
aussiejohn
10 weeks to go
With the tie rods installed into the steering arms in the holes that provided the shortest arm (and the fasted overall ratio), the overall vehicle steering ratio was 17.6:1. (With original production power steering the tie rods should always be installed in the holes with the shortest arms.)
With the tie rods installed into the steering arm holes that provided the longest arm the overall steering ratio for manual steering would be 20.2:1.
Now, if you want to change from the original production design. There are rack and pinion systems as well as integral power steering gears that can be provided by numerous suppliers. They can provide faster overall ratios and can also provide different valves with different steering efforts.
Jim
The internal worm shaft gear is the expensive part of the box and if you get a "rebuilt" with marginal gears, you may be no better off than you are now (or worse), and back to looking for another box in a few thousand miles.
These Saginaw boxes are very rugged and properly built (or rebuilt by one of the guys on this forum that does it right) should be good for 200,000 or 300,000 miles.
http://www.flickr.com/photos/39104031@N05/3596667182/
