I think my carburetor is ruined.. When I put the gas tank on there was a lot of debris that would accumulate in the gas filter so I had to take the retaining nut and gas line out a lot. One of these times I stripped the threads in the carburetor and gas leaks which makes the engine sound horrible and is probably detrimental if ran hard. Sealant has been applied that was supposedly for this problem but there still a leak. Is there anything else that can be done or do I need a new carb? If I do what should I look at?
Don't know what kind of carb you have but many have a brass or paper filter in where the fuel line connects to it. Make sure that filter is clean.
Of course a leaking gas line is detrimental to performance. It's hard to see out of the windshield with flames coming out of the hood so you have to slow down. You better fix that problem right away or you will be posting "My Vette burned to the ground".
There are plenty of replacement carbs available. If you have a stock engine something in the 600-650 CFM range is probably all you need. The Vette 350 isn't anything unusual when it comes to carbs. Any 350 Chevy carb will fit the engine.
Rick B.
This is a common problem with the quadrajet carb, and It's been a long time, But if my memory still works, I believe there is a kit to repair stripped threads at the fuel line inlet. But never the less, if you remove the carb and send it out to have the stripped threads repaired, there are a number of Carb rebuild shops.
There aren't many shops in south western PA that I'm aware of..if any. And they sell a kit from NAPA but the said they don't sell the quad-jet size inlet anymore for a 350 motor. The car doesn't run on road or far so fire hazard is minimal or at least containable at the moment but I really don't know of any carb shops anymore. Would it be worth having it fixed or going to the scrap yard since it'll probably cost the same?
...You mentioned Q-J what quadrajet would be in a *74' 350 auto w/air?...
A 7044206 for the L48 and a 7044210 for the L82. I'm guessing the only real difference between the two would be jet sizes.
While the carb is off and being repaired, clean the gook out of the tank and blow out the fuel line from the tank to the engine compartment. That will get rid of most of the gook you're picking up at the carb.
