AC questions???
Old Jun 4, 2009 | 10:09 PM
justin_heat05's Avatar
justin_heat05
Default AC questions???
Just installed a new ac system. The compressor was completely gone and there are no wires close by. What wires go to the compressor and what wires go to the thermostat.
Help appreciated.
Old Jun 4, 2009 | 11:00 PM
TimAT's Avatar
TimAT
Usual color for the compressor clutch wire is green/white stripe. What year car do you have? If the compressor was gone and the system was open for any length of time, you'll need to replace a couple of other parts and flush the system.
Old Jun 4, 2009 | 11:09 PM
C3bdj1's Avatar
C3bdj1
St. Jude Donor '10
I'll look tomorrow afternoon and tell you what I can. My memory is not as good as it used be.
Bobby
Old Jun 4, 2009 | 11:39 PM
blk79nj's Avatar
blk79nj
Here is a picture of mine... it's a '79
Old Jun 10, 2009 | 09:40 AM
justin_heat05
Originally Posted by timat
usual color for the compressor clutch wire is green/white stripe. What year car do you have? If the compressor was gone and the system was open for any length of time, you'll need to replace a couple of other parts and flush the system.
1979,
Wheres the yellow and green wires going to? I think mines missing all together
Old Jun 10, 2009 | 10:02 AM
08vycpe's Avatar
08vycpe
I have a '79 A/C car. It has a green and a black wire on the compressor, the black wire is ground and a light green and a blue wire on the high pressure switch near the compressor. There is also a light green wire attached to the idle speed solenoid that engages when the A/C is turned on. The car is totally stock L-48
Last edited by 08vycpe; Jun 10, 2009 at 12:12 PM. Reason: corrected wire color to blue at high pressure switch
To AC questions???
