Priority Start - battery is still draining to empty
Well, I agree that I should address the main reason, why the battery is draining, but until now I was not able to detect the problem. So let's leave it for the future. Now I just want to understand, why Priority Start unit does not disconnect the battery, as it is supposed to do. When connected, it makes some sound at the beginning, as the levers inside of it are moving, so I suppose that it must be working.
Any ideas are welcome
I have a 68. The 68 wiper system is notorious for causing battery drains. In fact it was designed to drain the battery if you accidentally leave the wiper freeze switch in the on position, even with car turned off!!
When I got my 68 the battery was dead. I immediately ran out and bought a new battery, oh joy! oh joy! car runs!!... next morning the new battery was dead. My short term solution was to install a battery cutoff switch. You should have one of these anyway for safety reasons. Every time I turn off the vette engine I reach around and disconnect the battery. I still do this, routinely. Still have the same battery I put in 10 years ago.
(I also pulled the wiper fuse, but I still disconnect the battery out of habit)
Regarding "Priority Start" I am not familiar with this device. Maybe they have their own website with tech support.
My boat died because of the radio, it never completely was powered off. After a week it would be dead.
My Vette's radio Amp was an incredible hog. If I listened to the radio for an hour without the car running it would drained it, otherwise it took a couple of days.
So I would examine your audio electronics to see if that is the culprit. Since I haven't taken steps to correct it yet, I always disconnect my battery.
Paul
somewhere or bad ground.. Mine was in the horn....
Good luck.....
