PCV / Breather / Oil cap question.
Old Jun 8, 2009 | 09:22 PM
rajsid's Avatar
rajsid
Default PCV / Breather / Oil cap question.
Hi guys,
My 69 BB has an HT 502 crate motor in it. I have been wanting dress it up like a stock 427 BB.
I am going to replace the valve cover with a stock looking chrome valve cover. To do this, I will have to make two modifications to the current set up.
1) Currently the motor has a crankcase breather. I will have to route it into the air cleaner.
2) The oil cap is on the drivers side valve cover. I will have to move it to the passenger side valve cover.
Is this going to be OK or will it make the motor leak all over the place? Is there anything else that I have to keep in mind while making this mod?
(should I even attempt this?)
Old Jun 9, 2009 | 12:08 PM
rajsid's Avatar
rajsid
I should have posted this on the C3 Tech/Perf. forum.
Mods, can you help me move this?
Old Jun 9, 2009 | 12:20 PM
spedaleden's Avatar
spedaleden
When you use the stock valve covers you will be fine.
To PCV / Breather / Oil cap question.
