difference in speedometers?
Old Jun 13, 2009 | 05:14 PM
onaqwst's Avatar
onaqwst
Default difference in speedometers?
i'm looking for a 77 speedo/tach and so far nothing. was curious if any off the older year speedo/tachs would work. would the gear ratio be different or tachs be off if i tried to use gauge from a 76 or older?
b
Old Jun 14, 2009 | 11:55 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
75 76 and 77 will work just fine. The rear end ratio plays no part in the speedo or tach readings. This output to the speedometer is controlled by the gear in the tranny and you won't need to change this.
Willcox
