Differential Removal on a '79
. I look and the differential is leaking from just about every possible seal. So now the question is what is the easiest way to pull the differential? Is this a job I could do in my 2 car garage or does it need to be farmed out? To me it looks like pretty much he whole suspension has to be dropped? The biggest job up to this point that I have done was the heater core so if there is a book/video/artice that would be great. Whatever rubber I will remove I will replace with poly equivalents.
1. Jack up rear end and support on jack stands/ lift is even better.
2. Disconnect and remove rear spring.
3. Disconnect/ remove half shafts and strut rods.
4. remove bolts securing front of differential/ drive shaft and loosen ( Don't fully remove) cross member bushing bolts.
5. Use a 2 jaw puller to pop the cross member bushings loose while supporting diff on jack (weighs approx 100 lbs) and then remove bolts.
Lower diff to ground and remove cross member from diff - 4bolts from top. Now your ready to tear down the diff.
I just did this in my garage - 4 post lift, northern tool transmission jack, lots of PB blaster and impact wrench. Also removed trailing arms, then gas tank, then rear bumper brakets. The while I'm at its really took over but I'll have fully restored rear chasis when I'm done. I'm going to have GTR 1999 do my diff and rear bearings.
Good luck. Not an intricate job, just need the right tools.
Just did this on a 78. I removed exhaust and tub and than got into what is described above. Two car garage, no-lift, one alumnimum jack and air tools. I would say at minimum you need the jack to lower differential and than raise it to a point you can bolt it and/or spring to crossmember and than differential. Also air tools while not essential, quicken time removing bolts and dropping parts.
