Question- Steering column rebuilders
Old Jun 18, 2009 | 06:47 PM
dalewilson99's Avatar
dalewilson99
Default Question- Steering column rebuilders
So I was thinking of getting my 81 tilt and tel rebuilt to repair the side play. any sugestions?
Dale
Old Jun 18, 2009 | 08:02 PM
blueray72's Avatar
blueray72
Dale
search for the Jim shea rebuild papers.....everything you'll need...except beer
Old Jun 19, 2009 | 02:42 AM
mechron's Avatar
mechron
Dale
yes, from a column rebuilder that drifted over from the C1-C2 section, i have rebuilt many C3 tilt teleys. along with many other cars with/tel columns. your problem is the pivot pins (a common problem). find somebody that knows how to repair these (like i do). the tilt/teley columns have lots of parts and require special tools to do one. you need to disassmble from the steering wheel down, then the lock plate, then the turn signal switch and also pull the key lock and the gears/linkage. then pull the telescopic mechanism. only then will get at the pivot pins, you need another tool to remove and replace them.
i did not even mention the springs and levers that make these columns work. they are a pain. the only forgiving factor is it can be done sitting comfortably in the drivers seat and laying the parts on the passengers seat...disassemble/reassemble. for an experieced tech, it's about a 4 hour job..
Old Jun 19, 2009 | 07:53 AM
lock-n-load's Avatar
lock-n-load
mechron , not stealing the thread but .. I use the tilt part of the mechanism every time I get in or out of the car ...
Is there a way to prolong the life of the system .( other then not using it ofcourse ). Im not looking forward to the repairs as stated above ...
thanks .
Old Jun 19, 2009 | 10:31 AM
Jim Shea's Avatar
Jim Shea
To prolong the life of your T&T column don't swing yourself in and out of the car using the steering wheel for leverage. It may be more difficult getting in or out but it definately will prolong the useful life of the column.
The most common long term problem with the Saginaw tilt and the T&T columns is the loosening of four critical support screws that are buried deep in the steering column head. They are a pain to reach since the steering wheel and quite a few parts must be disassembled in order to reach them.
However, there are really only two required special tools needed to perform the operation. You must have a steering wheel hub puller and you really need a locking plate compressor tool. I believe that both can usually be borrowed from most automotive stores.
FYI, I have fairly complete instructions posted at Terry Rudy's websight www.corvettefaq.com on the Tilt & Telescoping 1969-82 Steering Column Disassembly & Repair Papers #1, #2, & #3 as well as Disassembly & Repair Pics #1, #2, #3 if you are so inclined.
Go to the www.corvettefaq.com websight.
Look under Jim Shea's Steering Papers and then under Corvette Steering Papers.
Jim
Old Jun 19, 2009 | 04:51 PM
Jim Shea's Avatar
Jim Shea
If your are serious about sending your T&T column out for repair, there are a couple of businesses that specialize in steering columns. I don't believe that any of them are supporting vendors. So if you want some addresses let us know. We won't be stepping on the feet of current supporters.
Jim
Old Jun 20, 2009 | 12:17 AM
dalewilson99
Thank for the replies. I think I will try this job myself next weekend. Where I work I have a shop with every tool I could possible need and the help of a fellow worker who has had experience with columns similar to this. I have already printed Jims Papers (thanks Jim).
To Question- Steering column rebuilders
