C3 Legroom
Old Jun 21, 2009 | 07:16 PM
Mark D.'s Avatar
Mark D.
Default C3 Legroom
Happy Father's Day!
I'm considering getting a Corvette and have a question for you taller owners. Is there any year of C3's that offer more leg room for long legged guys? I'm 6'4'' and test drove a '71 but it was tight and my knees were high up. Are the later C3's roomier?
Thanks!
Mark
Old Jun 21, 2009 | 08:00 PM
early shark's Avatar
early shark
Mark,
Have the same problem in my two '71's. Have also owned three '70's, two '72's and have the same problem in '68 & '69 as well. I finally broke down and bought a '02 model just for the leg room.
Old Jun 21, 2009 | 08:04 PM
72LS1Vette's Avatar
72LS1Vette
Originally Posted by Mark D.
Happy Father's Day!
Thanks!
Mark
I woudln't count on it. All C3's use the same birdcage so the seats can only go so far back. Perhaps there were some changes to the footwell when the metal floor pans came into play but I don't think there would be significant increases in leg room. Perhaps other tall drivers will chime in with some suggestions. I'm only 5'7" on a good day so I fit fine. Your particular build will be a factor also if you are that tall. Sounds like you have long legs. A Vette with a tilt/tele wheel would give you more room for your knees and the wheel can be moved closer to the dash. You will probably still feel like you're driving a go-kart though.
Rick B.
Old Jun 21, 2009 | 08:10 PM
BKbroiler's Avatar
BKbroiler
I'm 6'3" and the leg room in my 77 is OK but I would have a hard time getting in and out without the tilt and telescopic column. Lots of the later C3s have them.
Old Jun 21, 2009 | 08:14 PM
cargo247's Avatar
cargo247
6'3 and i have an 81 tilt helps, auto helps as well no clutch pedal, its a tight fit but i like it that way
Todd
Old Jun 21, 2009 | 08:25 PM
Sebago Shark's Avatar
Sebago Shark
St. Jude Donor '09
I have a '78 and an '80. In '79 they redesigned the seats, (actually starting with the '78 Pace Car). Both have the tilt / telescope. The '80 doe's feel a little roomier. The seat pan seems to set deeper or closer to the floor and the back may be tilted back a little more. I just feel a little farther back in the 80 that the 78. Glass T-tops give you a tiny bit more head room also.
Find someone with a Pace car or '79- '82 just to try sitting in.
Old Jun 21, 2009 | 08:29 PM
jimo's Avatar
jimo
Rick B.
sometimes its good to be short!! im 5'8"
Old Jun 21, 2009 | 08:32 PM
Mark D.'s Avatar
Mark D.
Todd
I'm thinking automatic also.
Old Jun 21, 2009 | 08:33 PM
Mark D.'s Avatar
Mark D.
Good advice. I'm going to Bloomington Gold and I'll check out the cars for sale there. Thanks for the info.
Old Jun 21, 2009 | 08:55 PM
mrvette's Avatar
mrvette
6'5" here, height in backbone due to extra vertabra in lo back, with arthritis showing up 24 years ago, it's no better....
I lowered the seat in my '72, by taking off the rear mounting tabs worth about 1.5" used the old seat foam when recovering seats, removed the seat belt cover and some seat springs....I set LO in the car now....
then the addition of the TT wheel, i'ts a 78+ wheel/column assy, smaller diameter wheel and so moved it back 3/4 inch off the firewall to relax my arms a bit...
I cut a wide U cut from just below the steering column height on either side of the firewall/footwell, and across the bottom, forced the plastic forward about 3" and glassed it in again...
so then I heated/bent the gas pedal some 3" lower/forward, and then did the brake pedal the same way, cut the lever had a buddy weld it....
that pulled my legs off the steering wheel and gave lots of extra room, the elimination of that floor mounted dimmer and using it on the turn sign lever with the later shark column got rid of another silly bulge in the flooring too, room for my size 13 feet,.....also it used to be a stickshift car, automatic now, with the giveaway stick shift small brake pedal.....
Old Jun 21, 2009 | 09:07 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
The early ones seats are high and make you sit close to the wheel.
As mentioned the later ones seats are thinner and give some more room.
Old Jun 21, 2009 | 09:21 PM
Duke94's Avatar
Duke94
I have a 71' vert and a 78' coupe. I'm only 5'8" and I have the seat as far back as it will go in the 71' (it hits the deck lid). The 78' has more room in all directions. What ever you decide on, make sure it has a tilt/tele wheel as that makes a big difference.
Gary
RF1979C3's Avatar
RF1979C3
I am 6'5" about 250 lbs and I have a '79. The legroom is adequete for me, but if I were any taller it would be a problem. I think the later style seats help, I have sat in one of the earlier cars and they do not seem as roomy to me. Tilt/telescopic steering column is a must, and mine is an automatic. The footwells are small enought that i do not think I could comfortably drive a 4 speed in one of these.
Old Jul 3, 2009 | 09:55 PM
Mark D.'s Avatar
Mark D.
Okay, so I got to try on a couple of cars at Bloomington Gold. I sat in an '81 and an '03. They both were actually a good fit and much better than the split window that I tried on a couple of weeks ago. Thanks for the help everyone!
Old Jul 3, 2009 | 10:32 PM
AOVET's Avatar
AOVET
As long as I get to drive mine I don't care where my knees are. It's all good.
Old Jul 3, 2009 | 10:47 PM
SharkAttack's Avatar
SharkAttack
Gary
I'm 6' 2" and can confirm that a tilt wheel does help. My prior Vette (71 coupe) had it, my current 72 LT-1 vert does not. Leg room in all C3's is about the same from the factory.
Old Jul 4, 2009 | 04:05 PM
77vetter's Avatar
77vetter
I have a 77 and I'm 6'6" (38" inseam - so long legs) I could "fit" in mine ok but the turn signal forced my knee into the door panel. I shortend the turn signal as much as I could and that gave me the necessary room to allow my leg to move around a bit. Other than that, that was the only issue I had in being able to fit in my 77.
To C3 Legroom
