Replacing Brake System
Old Jun 25, 2009 | 10:57 AM
929nitro's Avatar
929nitro
Default Replacing Brake System
I am replacing my brake components calipers, lines, proportioning valve and master cylinder. If everything is new is it necessary to bench bleed the master cylinder? I will be using a vacuum bleeder to bleed the system. Thanks in advance for any advice.
Old Jun 25, 2009 | 11:06 AM
hicswa's Avatar
hicswa
I would. It don't take that long to do.
Danny
Old Jun 25, 2009 | 11:51 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Yes.
Old Jun 25, 2009 | 01:21 PM
Ganey's Avatar
Ganey
Yes. Some MC have beeders to bleed installed.
Old Jun 25, 2009 | 01:25 PM
70 LS1's Avatar
70 LS1
You have to bench bleed before you hook up the lines. This can be on the bench with a vice and screwdriver or in the car with short lines that go back into the master resevoir.
Old Jun 26, 2009 | 04:29 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
I must be missing something If it s A complete new system the fluid will just flow out make you re-fill several times What would be the advantage of getting the fluid in when your just gonna suck it right through?
Old Jun 26, 2009 | 09:37 PM
markdtn's Avatar
markdtn
You have to get the air out of the m/c before you install it. The air gets trapped and you can't get it out because the m/c is at an angle.
Old Jun 28, 2009 | 12:03 PM
929nitro's Avatar
929nitro
Thanks for everyones input. I was thinking like Vader Vette That you would be sucking thru the entire system anyway. Guess I will be bench bleeding.
Now does this mean that if the cylinder goes dry during the bleeding process you should bench bleed it again, not trying to be a smart a** just want to do it right.
Old Jun 28, 2009 | 01:23 PM
70 LS1's Avatar
70 LS1
Yes, if the master goes dry, you have to bench bleed again.
To Replacing Brake System
