battery indicator light
Old Jun 30, 2009 | 04:30 PM
TJ1980vette's Avatar
TJ1980vette
Default battery indicator light
the battery indicator light is always on, I replacerd the battery and the alternator, both new, and that didnt solve the problem. What should I try next?
Old Jun 30, 2009 | 05:48 PM
...Roger...'s Avatar
...Roger...
Pull the 2 wire plug out of the alt. and see if the light goes out.
Old Jul 2, 2009 | 03:53 PM
TJ1980vette
Thanks for your responce. I tried that and it did not work. However the choke light went out, which is another problem entirely, but the tach stopped working too. Could you tell me what that plug operates? How about another suggestion, where to now! Thanks
Old Jul 2, 2009 | 04:55 PM
...Roger...
The brown wire in that plug will turn on the Gen light if the alternator is not working correctly.
Old Jul 2, 2009 | 08:37 PM
KENS80V's Avatar
KENS80V
I had a similar problem back in the late eighties. It turned out that the charge wire that runs under the car from the alternator then up to the battery was broken at the lug next to the battery. Look for the stud in the battery compartment ....you'll see the charge wire attached to it and a second wire that feeds the battery. Wiggle the wires to see if the connection is good.
To battery indicator light
