512 block
Old Jul 2, 2009 | 01:21 PM
Tod74's Avatar
Tod74
1st Gear
Default 512 block
I have a 4 bolt main 512 block with a date code L19 8 on the side.The numbers on the pad on pass side can't be read because the block looks to have been milled slightly...I can almost make out a CF or a CE but not sure.This block is already bored .060 over and has one cylinder scarred up so it would need a sleeve. Is this a 427? Also, what is this thing worth?
