Check to be sure the 2 hoses are install correctly on the control valve. If they are, and you tried to balance the valve then your new CV is bad. Been there done that.
I just spent 6 hours trying to figure this out.... My mechanic kept saying the power valve to slave cylender hoses were right... .but they weren't crossing. I'm going to kill him.
it would just not center, fight itself from 10 to 2 to 10 to 2 to 10 to 2..
Are you sure there is not some kind of restriction in the system, is the power steering pump working properly, is there plenty of grease in the gear box? Just suggestions to try since you have installed two valves.
