i just finished putting a 383 crate motor and tremech 5 speed in my 68 ...i have wired the car the way the wiring diagram stated that i recieved via this web page ..the car turns over and fires once..and dies ..is there a wiring genius out there i could call to go over the wiring ???..it has msd coil and dist ...here are the wires that go to the starer one from the battery.....one from a relay over by the alt and the fender wall those two hook to the main power to the starter.. one yellow ...one purple...and another wire from the fuse box ..those three go to the smaller contact on the starter ..and one black ground from blower motor to starter bolt ground ..the stater is a jegs brand and has only two wiring points on it ..if ther is someone that has any idea what i have done wrong or why it wont run i really could use the help ..my cell is 616-634-0182 if you would like to call...the motor is a blueprint brand and was run and dynoed before shipping so i know the timing is right ..thanks for you time and help...fran
if it fires it is getting spark, the wiring of the starter would not effect the spark. Just to be clear, from the time the car was test run to installation in your car, the plug wires and the distributor were never removed?
Are you sure its getting gas?
From what you have stated, you are getting spark...have you pulled a plug and cranked the engine to see if it fires?
If you have spark, then you don't have fuel.
thanks for the reply..yes its getting gas so much you can smell it ...its like when i turn the car over and it fires and i release the key it dies ...that is why i think its got something to do with the wiring ..i am not sure if going to the new type starter with only 2 wire contact points from the old chevy starter with 3 on the sollenoid makes a differance
that wire would be the the wire that goes to the + side of the coil right ..it was hot last time i checked ,,i will check it again ..jegs also says i should not need to use the yellow wire that went to the R on the solenoid..is that right ..i am just grabing at things right now ..the car started right up the way it is wired right now with the old motor ..i have not changed a thing on the way it was wired ,only went to a new type of starter with only 2 wiring points instead of the one with 3 points on the solenoid ...thanks for your help...fran
Just reread your OP the small term on the starter should only have a purple wire on it. If the yellow is on at the starter and at the coil the engine will fire but will be killed by the yellow when you release the key.
What is the other wire you say is on this terminal that comes from the fuse box ?
there are 2 wires on the + side of the coil ..the brown multi color one from the wiring harness and the red from the msd dist ...on the - side of the coil the orange from the msd dist ..and a tach ground ...the yellow i did have hooked up to the starter and the car would not run ..took it off the car would not run ..i have looked at the fuse box the the other owner had a wire from the battery blade in the fuse box to the starter ..not sure why he did it ..but that is the way the car ran before..once again thanks for your help ..i really wanted to enjoy the car this weekend as i work for speed t.v and do not get many summer sundays off plus hagerty ins is haveing a car show in town and i wanted to be part of it ..but i guess not this year ..
Not familiar with the MSD wiring but if you will post a pic of the diagram I'm sure I could figure it out.
Make sure you dont have the yellow on the coil or starter,remove the tach ground from the neg side of the coil,make sure you have 12 volts on pos side of coil,-try to start
I think the fuse box wire should be on the batt term at the starter
sir thank you for the information...the car now starts ...when i get it cleaned up i will post photos of it and all that has been done to it ..if you would please call my cell so i can thank you ...616=634=0182...or if your ever around a nascar sprint cup race or the barrett jackson auctions fine me in the announce booth or at the speed stage ...thanks again ...fran
well does anyone know a good priest????? the car ran after taking off the yellow wire to the starter ..now it doesnt..i have no spark from the coil wire ..the + side is hot when i turn the key on ..the turns over fast ..but does not run got any idea why i would lose spark from the coil i only let the car run about a minute when it first fired up ...guess it time to get in my wifes trusty 72 shevelle and go for a ride ..thanks again fran
