The assembly instruction manual (AIM) or the GM Chassis and Service Manual will help. The AIM shows how the bumper covers were attached and what you'll find under them.
I am currently stripping the paint off my 80. Wasnt sure if anyone had a simple diagram of how to remove the front & rear bumper.
The front is the hardest the back is easy . the 10mm bolts need sprayed with PB Blaster the day before trying to re-move then just back out all the little nuts keep em I re-used mine they just needed cleaned up on the wire wheel.I also re-used all the hardware that holds the bumpers on I re-used all the stock stuff,except the bumpers of course I was Changing mine.Opening the headlight door will get you in to some of the tight spaces in the front.The pass top is the one I had the most trouble getting to.
Using a liquid spray to take off the two layers of paint and primer. They painted right over the orignal paint color. Works great, little messy. I am then using a 220 Grit Sand paper to get any extra primer let behind. I hope to have it ready for paint by Sept.
Thanks for the info. I saw the 10mm bolts, is that all I have to remove? How hard is it to remove the side front blinker lights?
Should be no big deal two screws. front and back.
Behind the 10mm nuts the re-tainer is in the bumper try not to distort those and you can re-use those also (I did). look at a pic of the re-tainer in the parts books and youll see what I mean you probably have them out by now.
