duraglass
Old Jul 7, 2009 | 02:38 PM
onaqwst's Avatar
onaqwst
Default duraglass
is there a better product to use or will this work for body filling.
plus looking at epoxy resin for fiberglass work....
Old Jul 7, 2009 | 03:26 PM
Fishndude's Avatar
Fishndude
Old Jul 7, 2009 | 04:26 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
evercoat fibertech then rage gold. the fibertech is smc compatible and is structural. the duraglass can be used on smc but not for structural repairs. it can be used with regular fiberglass though. the duraglass tech sheet states to use smc repair fillers on smc for strength. i would rather use the fibertech due to the better adheasion properties to smc. i have used both and i like the fibertech better.
Old Jul 7, 2009 | 04:35 PM
929nitro's Avatar
929nitro
I use ProGlass rather than Duraglass. Both by US Chemical but ProGlass is SMC compatable. For the resin I use All Resin also by USC.
Old Jul 7, 2009 | 04:36 PM
Fishndude's Avatar
Fishndude
Originally Posted by 2000FRCZ19
evercoat fibertech then rage gold. the fibertech is smc compatible and is structural. the duraglass can be used on smc but not for structual repairs. it can be used with regular fiberglass though. the duraglass tech sheet states to use smc repair fillers on smc for strength. i would rather use the fiber tech due to the better adheasion properties to smc. i have used both and i like the fibertech better.
Would this also work well for areas that have become thin due to excessive sanding from trying to remove major waves? My body is so wavy, its almost embarrassing to drive..
Old Jul 7, 2009 | 10:04 PM
markids77's Avatar
markids77
CAUTION: Blatant thread hijack ahead;The last time I worked on Corvettes, the "hot" sprayable filler was Evercoat Feather Fill. Which (if any) product mentioned here is closest to that product? Memory says this was a Polyester based material, as is the SMC (?) Thanks!
Old Jul 7, 2009 | 10:52 PM
noonie's Avatar
noonie
Have seen your work over the years.
You would have no trouble using epoxy and making your own filler tailored to your taste.
Buy the resin/activator for your cure time and add either cabosil or milled fibers to make a filler or even a panel adhesive.
Strongest and cheapest method without all the marketing hype.
Old Jul 7, 2009 | 10:55 PM
onaqwst's Avatar
onaqwst
i used that home depot resin crap and it seems to show a little over the years... i'm working on another forum members car with some molding ins and want to make sure we are 100% good.
when i worked on my 77, i used polyester resin, duraglass, and some evercoat feather stuff.
b
Old Jul 7, 2009 | 11:57 PM
noonie's Avatar
noonie
Epoxy doesn't have the shrinkage or adhesion problems that polyester does.
Old Jul 8, 2009 | 01:03 AM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
use epoxy resin on smc. the smc is poly based but has a mold release agent in it. this will cause the poly resin to have adheasion problems. you will have a lot less problem with epoxy resin in the future. spray the car with epoxy primer then put your filler on that. reseal it with epoxy primer and paint.
Old Jul 8, 2009 | 01:08 AM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
you may be better off laying a thin layer of glass with epoxy resin to gain the thickness back. then use filler where needed.
Old Jul 8, 2009 | 08:23 AM
929nitro's Avatar
929nitro
Old Jul 8, 2009 | 07:03 PM
onaqwst's Avatar
onaqwst
i think we might just use the epoxy resin right on the smc since we probably don't have a setup to prime yet.
Old Jul 8, 2009 | 07:06 PM
Fishndude's Avatar
Fishndude
What does smc stand for?
Old Jul 8, 2009 | 09:09 PM
ikwhite's Avatar
ikwhite
I use West systems epoxy for everything just as stated mix your own filler by adding what ever filler you prefer and tint to suit your needs.
http://www.westsystem.com/ss/
ikwhite
Old Jul 8, 2009 | 09:44 PM
markids77's Avatar
markids77
SMC + Sheet Molding Compound. In the early days of fiberglass, parts were formed in a mold by hand using either a 'glass non woven matting and resin, or a woven cloth and resin "laid up" by a technician with a bucket of polyester, a paint brush or roller and some fiberglass... one layer at a time. Sometimes the mold was sprayed with gelcoat before the part was laid up, sometimes gelcoat was applied to the finished, trimmed part.
SMC is a "prepreg"; pre-impregnated; material which is layers of 'glass with resin pressed into sheets which are shaped with large heated molds to form the part. The resin is "heat cure" as opposed to "hardener cure" like the old stuff. I'm not sure if the gelcoat is on the sheet pre mold, or added after. And I hope my info is correct or the glass gods will strike me down for sure!
To duraglass
