T top differences question
Old Jul 11, 2009 | 08:37 AM
mox_ct's Avatar
mox_ct
Default T top differences question
By now some of you know I have a 76 that I am putting back together. One thing I have found is the t tops are different. I believe my 76 used t tops with two latches. I have new smoke glass t tops with only one latch. Now I am wondering what's up with the difference? Can anyone shed some light on the differences?
Old Jul 11, 2009 | 08:21 PM
mox_ct's Avatar
mox_ct
ttt, somebody has got to know something about different t tops.
Old Jul 11, 2009 | 08:37 PM
DZRick's Avatar
DZRick
Wish i could help but I'm not sure when they changed. I'm sure someone will help you soon though.
Your post has only been viewed 26 time so let the guys wipe their cars down and they will be back online shortly.
Old Jul 11, 2009 | 08:46 PM
mox_ct's Avatar
mox_ct
Thanks for your enthusiastic reply. I didn't want the question to get lost without even one reply...
Old Jul 11, 2009 | 09:22 PM
dmeesq's Avatar
dmeesq
Im pretty sure the t tops went from 2 latches to one in 78. I know you can buy conversion kits for them, to add a second latch to the post 77 t tops
Old Jul 11, 2009 | 09:30 PM
LIQUIDDRAGON's Avatar
LIQUIDDRAGON
the original t-tops has a rear latch and the newer t-tops have a pin that gets pushed into a guide. you will have to replace the pieces on the car that the old latches hook to and put in the new guides. ask me how i know
Old Jul 11, 2009 | 09:57 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I posted on your other thread in tech. . . But this is the plate you need to change.
Also see my notes about a prior post in that thread.
Willcox
Old Jul 17, 2009 | 10:43 PM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
I have both, the orig. painted tops, and mirrored single latch tops. I use the mirrored tops and have had no problems. Whenever it comes time to replace the weather stripping in the mirrored tops, you will have to get the weather stripping for a '78 for it to fit. Weather stripping for my '75's painted tops wouldn't work. Found that out quickly, before any damage was done.
Old Jul 18, 2009 | 10:05 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
68-77 essentially the same - two latches no glass tops
78-82 essentially the same - one latch (part of anti-theft alarm system) optional glass available
78-82 tops can be fitted to earlier cars using the 78-82 hardware per Willcox' post. Purchase the AIM for your year and any 78-82 AIM and take a look at the diffferences in the two installations.
To T top differences question
