Help with Visor question please!
Old Jul 14, 2009 | 09:40 PM
vettecollector's Avatar
vettecollector
Default Help with Visor question please!
How do you get the Visor Rod out of the Chrome Corner Moulding piece on a 1979?
Thanks for any help.
Old Jul 15, 2009 | 02:32 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Very carefully. They can be cantankerous and can break.
You will find a retainer on the visor rod beneath the trim cap. The AIM will show the installation and helps when you have to remove one.
Good luck.
Old Jul 15, 2009 | 03:36 PM
TimAT's Avatar
TimAT
Very carefully. They WILL be cantankerous and can break.
Good luck.
Fixed it for ya!
Pop the cap 5/8 diameter off the top and carefully use an icepick to work at the tabs on the retainer. Odds are it'll pop off and die when it does. Good news is you can thread the end of the visor rod and put a self locking nut on it and it'll be all hidden when you put the cover back on.
Old Jul 15, 2009 | 04:22 PM
vettecollector
Thanks guys! A+
Old Jul 15, 2009 | 05:02 PM
BKarol's Avatar
BKarol
and if you would like a visual
http://www.corvettemagazine.com/2005...r/sunvisor.asp
To Help with Visor question please!
