advice please!
Old Jul 15, 2009 | 09:29 AM
crazy4c4's Avatar
crazy4c4
Default advice please!
I just got my first c3, now I get to start with all of the projects... First inspection is key, my horn works but will sometimes go off when I turn second my brake and blinkers work on the rear but no tail lights, already checked the bulbs and fuses whats next? thanks by the way it is a 1977 auto with t tops
Old Jul 15, 2009 | 09:53 AM
law dog's Avatar
law dog
Sounds like the horn contacts may be shorting out. I had to rebuild my horn with a kit from Corvette Central.
As for the lights, I had a similiar problem with my front signals and parking lights. After checking fuses and bulbs, the problem ended up being the Black connectors in the wiring harness where it pulls apart. I disconnected and lubricated the connectors.
No more light problems.
Old Jul 15, 2009 | 11:31 AM
rotgirl's Avatar
rotgirl
Pull out your v/o meter and check for continuity... and then voltage.
Old Jul 15, 2009 | 01:45 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by crazy4c4
...my horn works but will sometimes go off when I turn...
Horn contact is grounding when the wheel is turned. Pull the cap and contact and check the little plastic insulator. Careful: there's a spring in there.
...no tail lights, already checked the bulbs and fuses whats next?...
Make sure the rear wiring harness has a good ground on the frame. Wouldn't hurt to clean the area where it bolts to the rear X-member.
Been there, done that.
Cruise and enjoy.
Old Jul 15, 2009 | 01:50 PM
crazy4c4's Avatar
crazy4c4
still very very new to all of the c3 stuff just sold my c4 any pictures for the lights? I got the plastic insulator back in on the horn and havent heard it do the same thing again this morning thanks guys!
Jason
To advice please!
