Rear Window Storage tray, keeps falling down...?
Old Jul 17, 2009 | 05:02 PM
1ARACE's Avatar
1ARACE
Default Rear Window Storage tray, keeps falling down...?
Is this common? Also, whats the point of the 2 latches that the studs of the window slide into on the storage tray, they don't seem like they do anything to hold it securely in place; as they only slide over a little bit?
I know this may seem stupid, but the dam thing falls down everytime I hit a bump and is getting really annoying, is there a way to fix it?
Old Jul 17, 2009 | 05:31 PM
Frogday's Avatar
Frogday
I don't have a fix for this, but can tell you that my rear window has been in the storage tray for probably 500 miles now and has not fallen down. It could be something as simple as bending the latch so it makes better contact with the clasp.
Old Jul 17, 2009 | 05:38 PM
69monzacpe's Avatar
69monzacpe
I need to go look at mine, but if I recall when I re-installed the latch, it had slots that allowed it to be installed a little forward or a little aft depending on where the tray met the latch. Should be just two phillips head screws to loosen to adjust if I recall properly (it's been 4 years since I looked at mine).
Old Jul 17, 2009 | 05:59 PM
RPOL68's Avatar
RPOL68
I'm assuming this is on one of the fiberboard 68-69 widow tray designs withthe spring clip and not the push button.
You simply need to adjust the spring latch. There are two screws that secure the spring latch to the body. Loosen the screwsjust enough to be able to reposition the latch. Push the window tray up into position and let it hang on the latch. Slide the latch towards the rear so that it firmly and squarely contacts the tray. Then grasp the bootom end of the latch and pull forward to relase the tray. Be careful not to move the latch at the base where it secures to the body. Now with the tay down you have access to tighten the screws.
As for the swing clips. In order to properly position the rear window in the tray you must slide the top of the window, out side on the bottom, into the "L" clip at the back of the tray. In order to seat the window you must lift the bottom edge as you position the window in the "l" bracket. Then drop the bottom down flat and position the lower pins so that the swing clips will secure them to the tray. When properly positioned, the swing clips will hold the window down and keep it from sliding forward out of the "L" bracket.
To Rear Window Storage tray, keeps falling down...?
