'75 Speedo cable
Old Jul 20, 2009 | 08:18 PM
Doinit Once's Avatar
Doinit Once
Default '75 Speedo cable
My speedometer cable broke. I doubt if I'll be able to get the whole thing out via the trans connection 'cause that's the kind of luck I have. It has been many years since I had the dash apart and I've read the Haynes manual on getting to the connection behind the speedometer. If I removed the dash pad can I get to the connection. It looks feasible.
Mike
Old Jul 20, 2009 | 09:43 PM
The Spark's Avatar
The Spark
You can reach it from under the dash. Remove the a/c duct and you can reach it. It is a pain in the butt to hold the clip down and pull the speedo cable out. It helps if you have someone pull on the cable from the engine compartment while you hold the clip down.
Reinstall is easier.
Old Jul 20, 2009 | 10:47 PM
blk79nj's Avatar
blk79nj
Does your car have cruise control?
Old Jul 21, 2009 | 06:46 AM
Doinit Once
No cruise. I was wondering with that duct out of the way how much access I'd have. Thanks.
Old Jul 21, 2009 | 12:17 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader vette
Mike
you might get lucky it might just be the bottom line theres two on mine one from the tranny about a foot or so there is another on that goes up to the speed -o I would check the one going to the tranny first then put a drill on the top one see if it turns the speedo- (its A connector that I use to pump grease into the cable from your car should havi.
Old Jul 21, 2009 | 10:14 PM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
Find out which part of the cable broke before you start pulling the dash apart.
To '75 Speedo cable
