rust!
Old Jul 21, 2009 | 10:05 AM
Sundevil64's Avatar
Sundevil64
Default rust!
Can I use por15 and seam sealer for a semi-perm fix on this?
I was going to clean this with a wire wheel and por15 this any thoughts?
Old Jul 22, 2009 | 12:26 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Define, semi-perm fix ?
On the bird cage you would be fine,
however the door appears to be rusting from the inside,
that will return, ...the best method would be to media blast then POR15,
inside and out. 69VETT
Old Jul 22, 2009 | 02:57 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
In the second and third photos, what am I looking at?
Old Jul 22, 2009 | 03:58 PM
69Vett's Avatar
69Vett
#2 passenger side bird cage behind the door, just in front of the rear wheel well.
#3 side door window channel where your window felt is attacthed to the door
Old Jul 22, 2009 | 04:18 PM
avner's Avatar
avner
Sundevil64:
The problem will not solve in the door because i'm sure thre is rust on other side where the fiberglass attach to the metel frame and there the fiberglass will start to superate from the metal.
That what happend withe my doors I took the fiberglass out and fisx the door frames.
See pic's at my 72 garage.
Avner
To rust!
