Cleaning 79 Vette wheels
Old Jul 22, 2009 | 06:07 PM
uncle phil's Avatar
uncle phil
Default Cleaning 79 Vette wheels
I have a 79 Vette with the stock aluminum (I guess it's aluminum) wheels. What is the best thing to clean them with ?? I can't ever get them to look decent. I bought some Meguires "Hot Shine" for aluminum wheels today that I'm gonna try tomorrow.......is this good stuff ?? Any suggestions to make them look better ????
Old Jul 22, 2009 | 06:44 PM
79 vette head's Avatar
79 vette head
St. Jude Donor '10
Try the flitz ball
Old Jul 22, 2009 | 07:36 PM
ed1655's Avatar
ed1655
i've heard the powerball works great. one of the users here has a white 80-82 (really nice) and he restored the wheels with a powerball. he posted before and after pics on another thread somewhere. maybe he'll see this and chime in. good luck!
Old Jul 22, 2009 | 07:40 PM
uncle phil's Avatar
uncle phil
Do these work on a drill ?? I've seen things similar. Where can I find them ??
Old Jul 22, 2009 | 07:41 PM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
My rims were off the car but I think it went like this...step (1) 00 steel wool varsol & hot water & all cleaning was done in a circular motion not up & down. then it was soap & water & 1000 grit for what seemed to be hours & hours...then final polish with a Flitz ball & Flitz aluminium polish...outcome was excellent compared to what they were! Just remember there are tons of different ways to do this this is what worked for me Oh yeah if you're thinking of re doing the black inserts clean the rim good on both sides dry them off then spray you're flat black from behind before the cleaning it's faster than masking the rim later on! Try it on a small part of your rim first to see if you want to continue, this method is a bunch of work.
Old Jul 22, 2009 | 08:24 PM
uncle phil's Avatar
uncle phil
Sounds like it might be easier for me to go ahead and purchase those American Racing Torque Thrust Wheels I've been wanting .......hahahahahah
Old Jul 22, 2009 | 08:50 PM
ed1655's Avatar
ed1655
yeah. just google "mothers power ball". it's also prob available at most autostores (kragen, autozone, etc)
Old Jul 22, 2009 | 08:51 PM
RIJVETTES's Avatar
RIJVETTES
Its not so difficult, but the amount of time
you spend will depend on how tarnished your wheels are. I have an 80 with the aluminum wheels like yours: Wash them- plain car wash and water. Then get some Mothers Billet Polish, some VERY fine steel wool- like 00 or 000, and a clean soft cotton cloth. Then go to work polishing by hand- about 20 minutes per wheel or so. Wipe away he black tarnish. You'll see the shine come back. Then apply a top coat of regular car polish like Maguires NX to seal over the wheel. You're good to go for about a year. and the next polishing is A LOT easier and may not need much elbow grease at all....... Better get some sun glasses too!
Old Jul 22, 2009 | 09:26 PM
OURSHARK's Avatar
OURSHARK
Did you remove the clear coat the factory put on them? If not all the polishing will be useless.
Old Jul 22, 2009 | 09:35 PM
mds3013's Avatar
mds3013
Scotch brite pads also work well and don't put of metal splinters. But are more expensive. Come in two grades I have seen. Red coarse, Gray fine. Available at Pep Boys and Auto zone. Can be used wet. Follow with Mothers polish. Do not use any spray on cleaner that is Alkaline. Caused discoloration on mine. My '77 wheels did not have a clear coat but later models may. mds...
To Cleaning 79 Vette wheels
