engine identification from door plate
Old Jul 25, 2009 | 02:45 PM
gradys caars's Avatar
gradys caars
7th Gear
Default engine identification from door plate
This 74 rebuild is getting all consuming ... was looking at thread other day about VIN so went and looked at ours. Everything matched up but the code for the engine which shows "J" unlike what was posted the other day. Apparently built 9/73 as a 1974 model in St Louis. What kind of engine is a "J".
Old Jul 25, 2009 | 03:10 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
J is not an engine, you cannot tell what type of engine from VIN TAG.
Only if it is the orginal matching the Vin#
Old Jul 25, 2009 | 03:27 PM
Duke94's Avatar
Duke94
This will tell you what you have.
Gary
Old Jul 25, 2009 | 03:45 PM
73 454 vette's Avatar
73 454 vette
in the corvette vin i thought position 5 shows the engine size that was originally installed. letters were used and vary by year
Old Jul 25, 2009 | 04:30 PM
Mike Ward's Avatar
Mike Ward
If you're getting the J from the trim tag on the drivers door pillar post near the hinge, that's the date it was built.
If you are looking at the VIN tag on the windshield frame, on a '74 the J is for an L48 (base) engine.
The engine type became part of the VIN in '72 MY.
Old Jul 25, 2009 | 04:43 PM
ragtag74's Avatar
ragtag74
Default ragtag74
all of my plates were missing.The only plate I have is the vin on the windshield,I think the only original 1974 part on my car is the center grill. Ragtag
Old Jul 25, 2009 | 04:52 PM
ragtag74's Avatar
ragtag74
Default ragtag74
Has any one noticed that there are many more 74's on the Forum this past year.When I first joined I felt like the red headed cousin,I seemed to be the only one.Glad to have more of you around.It was the last of some features and the beginning of many. John
Old Jul 25, 2009 | 05:02 PM
gradys caars
7th Gear
Gary this is awesome thanks .... you realilze a monster is being created as now i have to go check all the numbers. I was told it is all number matching but now I can determine for myself ... thanks again. Gradys
Old Jul 25, 2009 | 06:34 PM
Duke94's Avatar
Duke94
That's the fun in owning an old car. Trying to figure out what you have. Here's another one so you can go check what axle and trannie you have.
Gary
Old Jul 25, 2009 | 08:45 PM
69Vett's Avatar
69Vett
opps I meant the trim tag. :o 69VETT
Old Jul 26, 2009 | 01:23 PM
glassman74's Avatar
glassman74
Gary
Gary,
My 74 trim tag reads: Chev--- N30, trim 416, paint 80L.
Production #37456
What am I missing? glassman74
Old Jul 26, 2009 | 02:09 PM
Mike Ward's Avatar
Mike Ward
Accurate reference info. The page shown above is not correct. '74 production ended in late Sept.74, probably on the 30th. Your tag was attached on that day and is the 6th from last car built for the model year.
The body colour chart is also wrong as GM had shifted over to a 2 digit code from 3 digit. 80 is Orange Metallic, L is for lower. Two tone cars had L and U for lower and upper body paint.
To engine identification from door plate
