Engine pics, (new at pics)
Old Jul 26, 2009 | 05:20 PM
Phil Zell's Avatar
Phil Zell
Default Engine pics, (new at pics)
http://s274.photobucket.com/albums/j...t=100_1274.jpg
There have been a few questions as to weather or not the L-98 angle plug AFR heads will work with the Hooker Super Comp side pipe headers, Yes they do.
Also the Weiand Air Strike intake is the only one I have found that you can run a double pump carb,(picture shown is a single pump 770 vac secondary), and still have a factory type vac. port.
I am also running Crane gold roller rockers under those factory valve covers.
Hope I didn't bore anyone, I am just playing with the picture thing.
Please forgive me for the rubber fuel line, not got that far yet.
Thanks for looking
Old Jul 26, 2009 | 06:53 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
Looking Good! How is your hood clearance with that setup. what style air cleaner and hood are you using?
Old Jul 26, 2009 | 10:19 PM
behardt91's Avatar
behardt91
Man! looks awesome! I really like the new valve covers. Looks really clean. Keep up the good work.
Old Jul 26, 2009 | 10:26 PM
wer2xu's Avatar
wer2xu
Phil when you go to the photobucket page with your picture look on the left side under SHARE THIS IMAGE.
You will see a line called IMG CODE
Simply click your mouse in that line, and you will see the word "copied" appear.
then simply paste that line into your post
volia!
Old Jul 27, 2009 | 07:59 AM
Phil Zell's Avatar
Phil Zell
Stock 75 hood
Using an after market drop base air cleaner base (Noah Performance)
Plenty of clearance
Old Jul 27, 2009 | 12:31 PM
BKbroiler's Avatar
BKbroiler
Looks good, but how are you keeping the plug wires off the headers?
Old Jul 27, 2009 | 12:33 PM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
clean! What fan are you running there on the rad? (I'm fabbing a tower brace and would like to convert to elec.)
Old Jul 28, 2009 | 06:26 AM
Phil Zell's Avatar
Phil Zell
Using strap ties for plug wires, just took the wire looms off to polish,
Old Jul 28, 2009 | 06:27 AM
Phil Zell's Avatar
Phil Zell
The whole radiator system is a DeWitt's, with the twin spal fan kit
To Engine pics, (new at pics)
