A/c help!!!!!!!!!
Old Jul 27, 2009 | 10:31 AM
1979super_vette's Avatar
1979super_vette
Default A/c help!!!!!!!!!
I am trying to put ac back in a vette that originally had it. most all of the components were removed. my big question is does someone make a more powerful blower motor??? i know that the rate that my friends 82 blows on high is nowhere near what im looking for on a hot and humid louisiana summer day. thanx
Old Jul 27, 2009 | 11:41 AM
TODWEELZ's Avatar
TODWEELZ
Can't help any but will be watching this post, my 80 has all components, but all hoses and belts have been removed?? would like to hook it back up but have never done this before waiting on a aim book to show that should help.
Old Jul 27, 2009 | 12:59 PM
mrvette's Avatar
mrvette
First thing you need do is pop out the old blower motor, and trace the outline of the mounting flange on some 3/4 plywood, or similar material...then you cut a hole in center to agree with a C4 motor/blower assy.....Auto Zone is one source for both as a assy....get a power plug while there....
the ground side of the stock blower is a black wire....it needs upgrading to 8-10 ga wire, and securely mounted to engine block the + feed has to be proven to supply full voltage to the motor with only less than a volt from full alt output being allowed....
the evap housing MUST be cleaned out, it's a bitch of a job....I just did it this morning for the second time in some 15 years now....i'ts a PIA type thing, and you should consider making the lower blower side of the housing easily removeable on the first attempt.....
I blocked the old fresh air intake from the wiper well, as I removed the inner flapper door, making the car a permanent recirculating system.....MY '72 is a convertible...enough with the air circulation already....YMMV....
so now you will have full airflow at higher output, and a much better/colder car....
Old Jul 28, 2009 | 08:59 AM
1979super_vette
thanx man, thats what i was thinking, its nice to hear that its worked out for someone before i start trying. i bought all new components so i will have to clean the evap box anyway before i install the new one. im most positive it hasnt been opened in 30 yrs, so that should be real fun . thanx again.
Old Sep 11, 2009 | 07:13 AM
Hawaiian turbo's Avatar
Hawaiian turbo
[/QUOTE]
Could you send me pics of how you removed the door and made it permanently recirc? I've been looking how to do this for some time now. I want to permanently fix the doors so the heater is closed and blowing through the upper vents all the time, and in recirc mode.
Pstova@hawaii.rr.com
Thanks!!!
Old Sep 11, 2009 | 09:09 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You want a C4 fan. It's larger and has a more efficient pitch to the blades than the C3 fan. It moves more air.
To A/c help!!!!!!!!!
