package shelf removal
Old Jul 29, 2009 | 11:47 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Default package shelf removal
78-82s. A couple years ago I had someone tell me you can't remove the black inner rear window trim unless the glass is out.
I've has guys say they refinished it in place
Finally got tired of the stickyness(anyone know why they sometimes feel that way?)and some scuffs and looked into it myself.
Took off one side of the interior halo panel, in my case the driver side, and extended the seatbelt as far as possible and laid the panel on the folded forward seats.
The package shelf maneuvered out easily. 10 minutes start to removed!
Couple applications of paint stripper and a good wash followed by a couple coats of flat black. I did use a gun to lay the paint on for better coverage.
Look like new again! I ended up doing 3 of them!
Old Jul 30, 2009 | 12:24 AM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
You should write a "How To" paper on it.
Old Jul 30, 2009 | 12:28 AM
KapsSA's Avatar
KapsSA
Well, other than "remove screws", that's pretty much it
Really been a matter of does it come out or not.
I've wanted to do this for a few years now. They look soooo good now
Old Jul 30, 2009 | 01:02 PM
kingkohlmn's Avatar
kingkohlmn
Veteran: Marine Corps
Default I know so little
What is a package shelf?
Thanks Bill
Old Jul 30, 2009 | 01:46 PM
KapsSA's Avatar
KapsSA
Thanks Bill
OK, rear window garnish molding. That clear things up?
Old Jul 31, 2009 | 01:14 PM
kingkohlmn's Avatar
kingkohlmn
It does now. Thanks
Old Jul 31, 2009 | 02:07 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...A couple years ago I had someone tell me you can't remove the black inner rear window trim unless the glass is out...
On the assembly line, the trim was installed after the glass was in place and the car had been through the water leak test.
To package shelf removal
