68 Deck lid info
Old Jul 30, 2009 | 10:46 AM
steve228's Avatar
steve228
Default 68 Deck lid info
The thread with this title:
(convertible latch pictures needed) ,had replies that posted pictures of decklids, with pins at each corner right and left.
I have a 68 vert project,and I have more than one illustration but, they are different.The one labled 68-72 does not show the pins.The others do.
Does the 68 model year not have those pins?
If it does,where do the pins insert into?
neither illustration that I have shows where they insert into.
TIA. Steve
Old Jul 30, 2009 | 12:16 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
68s do not have the corner pins. It's pretty much Plain Jane under the decklid. The AIM has good illustrations of what you want/need and the original part numbers.
Old Jul 30, 2009 | 02:11 PM
steve228's Avatar
steve228
Thank you..I looked at the aim.I just wanted to be sure,as stated in the OP I have other diagrams that show the pins...probably just generic dwgs.but captioned 68-72 so...
Thank's again for the answer.Steve
Old Jul 30, 2009 | 03:29 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by steve228
...I looked at the aim....
Here's a tip about AIM usage: if you're looking for a part and it is not in the AIM, it means that part was not installed on the assembly line. It was probably included in an assembly and the installation of the assembly will be shown in the AIM.
Engine are a good example. The engine section of the AIM begins with a long block and shows only those items added to the long block by assembly line folks.
To 68 Deck lid info
