74 headlight vacuum diagram needed
Old Jul 30, 2009 | 01:13 PM
Juniorbat's Avatar
Juniorbat
Default 74 headlight vacuum diagram needed
I dont see it in any book that I have, build or haynes, that shows the vaccum diagram for headlights.
I need it so I can operate the doors. Just the section pertaining to the headlights, I put vintage air in and have non original motor with various pcv, dist , trans solenoid ports for vacuum done already.
Old Jul 30, 2009 | 03:37 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The '74 AIM lists the vrious color codes on the vacuum tubing.
Old Jul 30, 2009 | 05:49 PM
...Roger...'s Avatar
...Roger...
The above diagram posted by Easy Mike is an INCORRECT DIAGRAM----- DIAGRAM IS INCORRECT---Please Email Corvette 101 and ask them to correct this diagram or delete it from their site-PLEASE --- Below this INCORRECT diagram is the same diagram with the hose positions CORRECTED. Scroll Down.
The above diagram posted by Easy Mike is INCORRECT !!!
Below is a corrected diagram.
To 74 headlight vacuum diagram needed
