Hi, can you help me to decode my BB in my 70 vette?
my casting number is 14015445, i found that is a 78-90...on the other side the number is f25-2. do you know the exactly date?
the pad engine is T0722XCH, is a good engine? how can i see if is 2 or 4 bolt?
thanks
in the next days i'll see the head number..
14015445 is commonly used in light/medium duty truck engines. To my knowledge, they are the last breed of MkIV, thus they have the least amount of metal in them, I think they are good enough for up to .060 over bore, but cannot handle .100+.
thanks
14015445 is a 78-90 454.
f 25 2 date code for June 25th, 2 is year so based on above would be 82.
T0722XCH enigne code, T=Towandowa (sp) engine plant, 0722 is assembly date (July 22nd which is in line with the June 25 casting date), and XCH is useage code and I could not find any listing for a big block with the XCH code.
tom...
I could not find a XCH useage code either....and I really tried! All the above fall's in place other than that. Maybe the OP needs to re-check the numbers...just don't know?
