Center Console Bolt
Old Aug 6, 2009 | 09:48 AM
Steve~74's Avatar
Steve~74
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
Default Center Console Bolt
How do you get to the center console bolt between the seat back wall?
I pulled the carpet but still can't see the bolt?
Thanx in advance.
Steve
Old Aug 6, 2009 | 10:04 AM
eastltd's Avatar
eastltd
Access the bolt from the rear storage compartment.
Old Aug 6, 2009 | 10:27 AM
Steve~74's Avatar
Steve~74
Damn......that's one tough bolt to get to.
Thanx East.
Old Aug 6, 2009 | 10:51 AM
PETKAH's Avatar
PETKAH
When putting back together just use a bolt in the back and nut in the front so you can slide the console back on - it will hold and make it easier to get to the next time.
Old Aug 6, 2009 | 11:11 AM
Steve~74's Avatar
Steve~74
Hopefully there wont be a next time, oh wait, this is a 35 year old car, the next time is just around the corner.
Thanx for the tip.
Old Aug 6, 2009 | 04:45 PM
Steve~74's Avatar
Steve~74
Passenger side power window wouldn't go down last night. I thought it might be the switch since the drivers side worked. That's reason for removing the center console. Well, decided not to remove the console b/c that bolt was tricky to get to. Then about 1/2 hour ago, I tried the window again and it worked. It sounds different than the drivers side so I am guessing its the motor or something in the door panel.
Question: Are these cars possessed or just fickle old machines that we love?
Old Aug 6, 2009 | 05:28 PM
BTAL's Avatar
BTAL
St. Jude Donor '09
Did you check for power to the motor first? It's easier to pull the door panel than the center console. If you have power at the motor then use a jumper wire from the battery to test the motor.
Also, at least in the later years you can pull just the front part of the console, where the switches are without pulling the rear.
Old Aug 6, 2009 | 05:31 PM
Steve~74's Avatar
Steve~74
Not yet, but that is my next move.
Old Aug 6, 2009 | 06:46 PM
GREGG-73's Avatar
GREGG-73
Steve, they are possessed...trust me on this. I see where you are located...so, make room for a New 73 convertible in town...Surf City area.
Old Aug 6, 2009 | 07:33 PM
Steve~74's Avatar
Steve~74
I go over to LBI often, drop me a line when you are down the shore. We will cruise to the Light House.
Old Aug 6, 2009 | 07:36 PM
Gordonm's Avatar
Gordonm
We need to have a get togther at LBI sometime with C3 Vettes. I'm in Brant Beach most of the summer. Early September would be nice. Not so crowded but still warm.
Old Aug 6, 2009 | 08:22 PM
Steve~74's Avatar
Steve~74
I'm IN.....I will post something in the EVENTS forum soon.
Down by the Lighthouse in Barnegat Light would be a great place to meet and take a cruise down to Holgate and back. Great spot for pics too.
Old Aug 6, 2009 | 09:11 PM
Gordonm's Avatar
Gordonm
You do that and you will have nothing but C5 and C6 cars there with tons of wax.
To Center Console Bolt
