68 327 , Carburetor help needed
Old Aug 9, 2009 | 10:19 PM
ksbunting's Avatar
ksbunting
Default 68 327 , Carburetor help needed
I posted this on the Tech section but maybe someone over here can shed some light on my carb problem today.
My 68 coupe with small block has a stock Rochester that was completely restored and then tuned for me by Lars.
Ran fine all last year and this year until 2 weeks ago when I last filled the tank.
Had to get towed today as it runs for a mile and then stalls and sputters and dies. I let it sit for a few minutes and it runs fine again for another mile or so.
I think I have water in the carb bowl and when I drive it sloshes around and stalls out or I may have dirt and sediment by the needle and seat.
My question is , how do I get the water out of the carb without screwign up all the settings and adjustment Lars did for me that made it run perfect like a swiss watch until this happened?
Is there a filter on the side of the carb where the fuel line enters, other than the can type mounted on the front of the engine in the fuel line?
Thank you in advance,
Kurt
Old Aug 10, 2009 | 09:58 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Sounds likes you got a tank full of bad gasoline (water). You might get away with a can of HEET or similar fuel drier.
Good luck.
Old Aug 10, 2009 | 11:49 AM
in2fun's Avatar
in2fun
Kurt
The Rochester Quadrajet has a fuel filter located in the fuel inlet connection.
The filter is # 56
Are running the stock ignition system? If not take a look at this thread. This guys car was doing some what the same thing. My car was also doing the same thing but I run a MSD ignition and it ended being the Box.
http://forums.corvetteforum.com/c3-g...yesterday.html
The fuel pump can be the problem too. But I would test it first before replacing. Start with the Fuel filter.
Old Aug 10, 2009 | 05:16 PM
ksbunting's Avatar
ksbunting
Thank you gentlemen
I will check the fuel filter for signs of water droplets and if I find any, I will give the HEET a try.
I assume it can be bought at NAPA or AutoZone
Kurt
Old Aug 10, 2009 | 09:23 PM
ksbunting's Avatar
ksbunting
Fuel filter in carb was perfectly clean and no obstruction when I blew through it.
Fuel hose to pump looks kinked; could be the culprit
Kurt
Old Aug 10, 2009 | 09:49 PM
CCrane65's Avatar
CCrane65
Kurt
Kinked? Do you have a rubber fuel line?
cc
Old Aug 10, 2009 | 09:54 PM
ksbunting's Avatar
ksbunting
Yes, a short section of rubber line goes from the metal gas line on the frame to the inlet on the pump.
Same for the return line but that one is more direct.
The large rubber feed line seems to have a sharp bend in it that looks like it collapsed slightly. It was new less than 2 years ago when I finished the restoration.
Need to get the car up in the air to get better access to it from underneath
Kurt
Old Aug 11, 2009 | 08:34 AM
Easy Mike's Avatar
Easy Mike
The line-to-pump hose is a molded S hose. It should not be straight, but neither should it be kinked.
Old Aug 11, 2009 | 08:49 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I have had fuel pumps that, when beginning to go South on me, work intermittently for short periods.
Old Aug 11, 2009 | 12:32 PM
ksbunting's Avatar
ksbunting
Easy Mike,
The molded "S" hose is for the fuel return line; it is smaller diameter.
The one that is kinked is the larger diameter feed line that goes from the frame to the pump.
My books only show the "S" hose for the return.
Kurt
Old Aug 11, 2009 | 06:45 PM
SteelCityBlue's Avatar
SteelCityBlue
just a suggestion but you may want to put an extra filter in the fuel line. I did and never had a problem since.
Old Aug 11, 2009 | 10:33 PM
tnovot's Avatar
tnovot
Kurt
Newer rubber fuel line does not necessarily mean it couldn't be the problem. Cheap (foreign made) lines have been know to fail prematurely - especially since it is on the suction side of the pump. Using gasohol could have softened the rubber too, if you use gas with alcohol.
If you use gas dry, it is better to use isopropol alcohol rather than methyl alcohol since it is less corrosive and harmful.
Terry
Old Aug 16, 2009 | 05:53 PM
ksbunting's Avatar
ksbunting
It is fixed and running well.
The culprit was the rubber fuel feed line going from the metal fuel line attached to the frame, over to the fuel pump.
It had a kink in it and the rubber was starting to crack.
Replaced it with new style rubber fuel line $7.50per foot) that can handle the ethanol and looped it so as to eliminate possibily of kinking again. Took it out for a run and runs great, no bog, no hesitation. Glad it wasn't that carb or needle and seat inside the carb.
Thank you to all for your input.
Kurt
To 68 327 , Carburetor help needed
