I hate
Old Aug 12, 2009 | 02:37 PM
sentinal77's Avatar
sentinal77
Default I hate
TRAILING ARM BOLTS
had to cut both and it took forever
sorry just letting off steamm :o
Old Aug 12, 2009 | 03:01 PM
emccomas's Avatar
emccomas
happens all the time. Very few get lucky enough to have the come out easily. I am looking at the same job on my wife's 79.
Old Aug 12, 2009 | 03:25 PM
GD70's Avatar
GD70
This is the one job I may have someone else do when the time comes.
So now that you did it, would you have a shop do it?
Old Aug 12, 2009 | 05:01 PM
sentinal77's Avatar
sentinal77
absolutely not, it only took $14 and a couple hours.. of hell
Old Aug 12, 2009 | 05:57 PM
temvette72's Avatar
temvette72
I feel your pain! You'll probably hate putting the new ones in as well!
Good Luck!
Temvette72
Old Aug 12, 2009 | 06:07 PM
GD70's Avatar
GD70
Then I may do it myself after all.
Glenn
Old Aug 12, 2009 | 09:43 PM
RIO68's Avatar
RIO68
Default bolt cut
Hey guys, the hot tip is the "blue tip" wrench! Cuts then right off in short order just be sure you do not have any fuel leaks!!
Old Aug 12, 2009 | 10:07 PM
c3_guy's Avatar
c3_guy
I just took the pivot bolt out of my left TA last night. Only took about 3 minutes to get the bolt out, what's the big deal. Well come to think of it, the last time I took it out it took about 3 hours. So if I take it out 100 more times the average time to remove it will be under 5 minutes.
Old Aug 16, 2009 | 05:33 PM
chstitans42's Avatar
chstitans42
TheCorvetteBen
Ha little brother, i guess I had better luck than you did. Mine pretty much just fell out.
Old Aug 16, 2009 | 10:26 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
I cut mine out last month. Not the most fun spent on my car for certain, but I wouldn't use a shop to do it, just take your time and be patient with it, you'll get them out.
Name:  Left Rear Trailing Arm.JPG
Name:  Rear End Empty Items Remaining.jpg
Name:  Rear End Out (2).JPG
I could not believe the amount of rusted parts in the rear end of my 77 Project car, but now, well look for yourself.
Name:  Rear End Paint Completed (10).JPG
Name:  Rear End Paint Completed (3).JPG
Name:  Rear End Paint Completed (21).JPG
New rear parts go in soon.
David
77Sleeper
Old Aug 16, 2009 | 10:50 PM
dprinter1's Avatar
dprinter1
Default T/A Job
My first experience with my 71 was prying, gouging, ripping , taring the brake pads out so I could get the car on the trailor for the 500 mile trip home.
Second experience......Hours and hours of cutting the T/A's out. There is no way I would let some "SHOP" do that kind of work on my Vette, no way. After years of getting screwed by "SHOPS", I'm convinced that there is no one on this planet that would take the time, nor put the care and love into a job on my car as I would. And I'm certain they wouldn't do it for the same price as I would
Old Aug 17, 2009 | 12:34 AM
...Roger...'s Avatar
...Roger...
Also if you use a torch watch you don't set the carpet on fire just behind the frame rail.
Old Aug 17, 2009 | 03:44 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
I'm with that idea, DW. Too many things under there that burn really easy unless you have the car on a lift for extra control. Lying on your side with the car on jackstands is bad enough and with a lit torch, well... I'd want to practice more before trying that on my own ride. I'm just sayin'.
My sawzall handled the problem in less than 10 min per side and nothing got burnt. Didn't even break the blade, either side. Worked for me.
Old Aug 17, 2009 | 05:05 PM
...Roger...
I use the torch as a last resort but the first time I did use a torch I peeled back the carpet and backing to keep an eye on it and I was surprised how hot the fiberglass got behind the seat. When using the torch now I run water between the frame rail and the body and wet a towel for the inside,messy but well worth it. Sure wish I was rich and could afford to buy and try a plasma cutter when I can't get the shims to cooperate. Until then my old Milwaukee sawsall will have to do.
Old Aug 17, 2009 | 05:06 PM
...Roger...
How many blades did you use ?
To I hate
