Fuel line issues-anybody else?
Old Aug 14, 2009 | 08:30 PM
straub18045's Avatar
straub18045
Default Fuel line issues-anybody else?
OK, just got back from the track with another dissapointing run. my issue is im running out of fuel at the top end, just put the holley 170 gpm pump with regulator at 7.5 psi, so my pump is not the issue, engine builder says i need 1/2'' line now, and i can only suck so much threw a straw. i run better on street tires i think because i only have issues when im running the drag radials, must be the g force pushing the fuel back to the tank. so how many of you guys had to upgrade to 1/2'' fuel line and how did you run it?
my combo-
kb forged pistons
pm connecting rods
rhoades lifters
late model block
eagle crank
edelbrock rpm cam
edelbrock large valve e-tec heads
airgap intake
built q-jet
gm hei
11.13 compression
not dyned but est. 475 horse
700r4 conversion
stock rear
Old Aug 14, 2009 | 08:34 PM
straub18045
oops thought i was in technical forum
Old Aug 14, 2009 | 08:56 PM
73 454 vette's Avatar
73 454 vette
bs on needing 1/2 inch line. the engine can suck more fuel thru a 1/4 inch line than it can use. if you were running out of fuel you would be knocking and having alot of other issues. i came from a 635 hp awd twin turbo car and even that used the stock line from the fuel tank.
i would check your fuel filter for clogs or put an aftermarket inline filter in and another thing to look at if your sure its a fuel issue is get a baffeled fuel cell if you track it alot.
how are you measuring the 7.5 psi fuel pressure
Old Aug 14, 2009 | 09:08 PM
straub18045
fuel gauge off of regulator @ idle, also when it does 'run out of fuel' it carrys on alot, i get out of it then im fine,
Old Aug 17, 2009 | 06:10 PM
Matt Gruber's Avatar
Matt Gruber
does the qjet have a filter in it?
Old Aug 17, 2009 | 06:38 PM
Gordonm's Avatar
Gordonm
The stock fuel line feed 600+ HP L88s in their day. It will easily feed you combo. No need to go to a bigger fuel line. Something else is the problem. Check from the fuel pump to the carb, I'll bet there is a restiction or a clog.
Old Aug 20, 2009 | 12:26 PM
Matt Gruber
if the e-pump is up front, u may have to move it to the rear.
or did u sell the car
Old Aug 20, 2009 | 12:42 PM
MelWff's Avatar
MelWff
Are you sure the float is set correctly? There are two small holes in the inside of the q-Jet that feed fuel to the secondary pickup area. Have they been increased in size from stock? This modification is cover in books such as How To Build and Modify Rochester Carburetors by Cliff Ruggles
To Fuel line issues-anybody else?
