1977 Corvette
Old Aug 16, 2009 | 05:29 PM
Jeffersongs's Avatar
Jeffersongs
1st Gear
Default 1977 Corvette
I'm rebuilding the Tilt/Tele column.
Looking for an "ignition actuator rod" and "FingerLock" housing/shroud.
Does anyone know if actuator rods are interchangable on some year models?
Eddie J
Old Aug 16, 2009 | 05:55 PM
Ganey's Avatar
Ganey
Eddie
Jim Shea is the resident st. column expert & would know. He posts & has written several papers on the st. columns. His articles should be at corvettefaq.com
I expect the "ignition actuator rod" is interchangeable on many models.
Old Aug 16, 2009 | 08:16 PM
Jim Shea's Avatar
Jim Shea
The T&T actuator assembly is the same 1977-82. It is available through Dr. Rebuild
The finger inhibitor shroud is unique for 1977 because the instrument cluster was carryover. I believe that the 1978-79 and the 1980-82 shrouds can be reworked to fit your 1977.
The shrouds are listed at Corvette Steering Service Inc.
Jim
To 1977 Corvette
