Will this work? Mirror mount question
Both side mirrors need the fibreglass redone as over the years it's had more mirror holes drilled than I care to understand why.
What I was thinking of getting done is asking the fibreglass guy to fibreglass a metal plate between the layers so that when the glass is finished off I can drill and tap a thread for the mirrors to mount to.
Will this work? Does anyone have any suggestions or any other better ideas?
Allan.
Allan.
The factory never installed passenger side mirrors on 70 Corvettes. These were dealer installed, so there never was a nut plate in the passenger side door. Passenger side mirrors were installed using "wellnuts". Wellnuts work like a dry wall anchor. A wellnut is a rubber grommet with a metal inside thread, when a screw is threaded in to it, it pulls up tight, sandwiching the fiberglass. People have used the wellnuts in the drivers door when the nut plate is missing. If your going to the trouble to install a new nut plate in the drivers door, you could buy one for the passenger side also or you could use wellnuts in both doors.
I am aware of the metal strip behind the left mirror, but it'll be gone when all the glass gets cut out and replaced.
I'm also aware that the right side has no strip and of the use of wellnuts.
I was however looking for a better/more guaranteed solution.
New question:
How was the metal strip originally attached at the factory. I might be best off to try and mimic this.
