jake74
Old Aug 25, 2009 | 09:39 PM
jake74's Avatar
jake74
Cruising
Default jake74
I have a 74 coupe,speakers are blown so I want to remove dash pad to install new ones and want to replace kickers,any help removing dash pad. Thanks in advance
Old Aug 26, 2009 | 09:51 AM
Peeps9823's Avatar
Peeps9823
Passenger side is easy, just remove the screws on the dash and the gauge cluster. Drivers side you have to drop the steering collum (2 bolts underneath), then take out the screws on the dash and the gauge cluster. It's been a long while since I did this procedure, so I'm sure if I missed a step, the fellas on the forum will put you back on track. Good luck on the job!
Old Aug 26, 2009 | 11:19 AM
Ganey's Avatar
Ganey
The pad is also attached to a bracket underneath on pass. side towards the middle. The sp. can be removed w/o lowering st. column by removing windshield trim. I just lifted the pad a little to remove dr. side sp.
Sounds like you have speakers in the kick panel locations.
Old Aug 27, 2009 | 12:58 AM
jake74's Avatar
jake74
Cruising
Thanks for the help,I'll give it a try
jake74's Avatar
jake74
Cruising
Thanks good advice
Old Aug 29, 2009 | 12:35 AM
jake74's Avatar
jake74
Cruising
Default speakers done
Did dash speakers today. Not difficult just time consuming.Thanks for tips,I did drop steering column I think it made things a little easier to move without forcing trim. One screw on defroster vent had to be removed with stubby screwdriver,also the dash bracket located right of defroster vent had to be removed to access screw holding vent.
Took header cover,pillar covers off also.Thanks for help
To jake74
