What engine does a 70 LT-1 have?
Old Aug 27, 2009 | 04:25 PM
RagTop69's Avatar
RagTop69
Default What engine does a 70 LT-1 have?
I was at a car show last night and saw a really trashed looking 70 Corvette with a big block hood and LT-1 striping on the power bulge. I was duly impressed and thought that the car might be a great restoration when I noticed a couple of things. First, it had a radio and I thought the LT-1 came with the radio delete. Second, I thought that the LT-1 had a very high performance 350, but when I checked the plaque on the console it showed 300 hp and a 9.5:1 compression ratio. Isn't that a base 350 in a 1970? I am assuming the car was a fake and the only thing "LT-1" about it was the stripes on the hood.
Old Aug 27, 2009 | 04:30 PM
moosie982's Avatar
moosie982
Yup, base motor, that year the LT-1 is 370 horsepower. Many other telltale ways to figure it out also as to what is what. Was it for sale and if so as what ? Peace,,,Moosie
Old Aug 27, 2009 | 04:37 PM
RagTop69's Avatar
RagTop69
No, not for sale. Just sitting in the middle of the show with all its cracks, chips and flat red paint showing. The LT-1 stickers looked really old. Maybe he found an LT-1 hood, or maybe a prior owner put them on the car.
Old Aug 27, 2009 | 04:54 PM
Kellys~hotrods's Avatar
Kellys~hotrods
According to my book, "Original Corvette", the 1970 LT 1 was a 350 C.I. 370 H.P. solid lifter motor with a high rise intake manifold and holley carb. The intake/carb made it neccesary to use the big block hood in these cars. The engine block cast numbers should start with 397010 and the 370 H.P.suffixes are:
CTU:370 H.P. holley 4BC, mech lifters, manual, TI
CTK:370 H.P. holley 4BC, mech lifters, manual, TI
CTV:370 H.P. holley 4BC, mech lifters, manual, ZR1
The intake manifold for the 1970 LT1 was aluminum (70 only, cast # 3972110)
In 1970 there were 1287 LT 1's produced and the option was a whopping $447.60.
It is believed that only 25 ZR1's were made in 1970, and the only way to verify seems to be through the tank sticker.
The LT 1's came with a copper radiator except for the ZR1's (which had the aluminum Harrison rad.).
Hope some of this stuff helps!
Kelly
Old Aug 27, 2009 | 06:05 PM
CCrane65's Avatar
CCrane65
Quite a few base motor cars had A/C but NO LT-1 did in 1970 so if you saw a compressor that's another dead giveaway.
cc
Old Aug 27, 2009 | 07:53 PM
mstanton's Avatar
mstanton
LT-1s could be ordered with a radio. The ZR-1 package, which came with the LT-1 engine, could not be ordered with a radio. The only restrictions that I'm aware of with the LT-1 were no auto, no a/c (until late 72), and no power steering on the early 70s with CTU engine suffix.
Old Aug 27, 2009 | 08:23 PM
Ironcross's Avatar
Ironcross
The LT1 Corvette got its name from the engine not the hood or stripe...without the engine its not a LT1.
Old Aug 27, 2009 | 08:46 PM
joewill's Avatar
joewill
any car that has its engine ever apart can have just about any engine in it, and just about any internals inside it also.. a 39 year old car may have just about anything in it... if you are interested then do your research here and you will become more than a novice! A LT1 Hood does not a LT1 Car make.. it is a corvette with an LT1 hood, and that is all.. it may be more, but research has to be done to prove it.
Old Aug 28, 2009 | 10:06 AM
WayneB_LT1's Avatar
WayneB_LT1
Look for the TI distributor too, if not there it may have been replaced but the amplifier box will more than likely still be mounted. The amplifier box is usually toward the front ahead of the radiator on the driver side and a bit difficult to get to. It was placed there to avoid heat as the transistors where susceptible and could fail, which is why a lot of distributors were replaced by an owner that wasn't aware of how they worked thinking the failure was in the distributor and not the box. Today you can replace the old circuit board with modern chips that don't have that problem.
Old Aug 28, 2009 | 11:23 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Swapping on an LT1/BB hood was popular and relatively easy to do. My '68 had an LT1/BB hood on her when I got her.
Dull paint, cracks, chips...sounds like the old girl has potential. She might need a nip/tuck, but she was out and about and sitting at the show.
Bless her old bones.
Old Aug 31, 2009 | 09:53 AM
thread baron's Avatar
thread baron
Also the LT-1 would have the 6500 rpm redline on the tach. Only the LT's and the Big blocks had 6500 red lines.
Old Aug 31, 2009 | 10:01 AM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
1970 LS-5 tach = 5600 redline. I wouldn't bet my house on it, but I would bet a beer....
Old Sep 1, 2009 | 01:00 AM
70Donnybrooke's Avatar
70Donnybrooke
That would not even be a correct plaque for a base engine. My 70 is 10.25:1 with 300 hp and I think 380 torque.
Old Sep 1, 2009 | 01:14 AM
mstanton's Avatar
mstanton
You're correct. Only the LT-1 had 6500 redline in 70. Solid lifter big and small blocks tended to have the 6500 tachs. (LS6, LT-1, L-71, L-72, L-76, L-84, L-88)
To What engine does a 70 LT-1 have?
