Please help with A/C fitting sizes
Old Sep 1, 2009 | 08:28 AM
SharkintheWoods's Avatar
SharkintheWoods
Default Please help with A/C fitting sizes
I am in the middle of building some A/C hoses for my 1980. The old hoses no longer worked due to the serpentine setup I have off an F body. My dilemma is this, I am trying to use the compressor block fitting to crimp new hoses on. It was off an 89 camaro. The tube ends out of the blocks are the standard 1/2 and 3/8, but then they step down slightly after the ridge in the tubing and the hoses don't fit snugly. Is there a metric hose size they used on these cars? I have used 8,10 and 12 hose sized, but none fit well. Any clues?
Old Sep 1, 2009 | 09:24 AM
corvetteload's Avatar
corvetteload
I suggest going to a pneumatic hose shop in your area, they will have the right size and be able to properly crimp them.
Old Sep 1, 2009 | 11:54 AM
SharkintheWoods
Since I have access to a crimper, I didn't want to go that route. I just want to know why the fittings on a newer GM car are slightly smaller then what came off my 80. The original fitting fit perfect.
Old Sep 2, 2009 | 11:45 PM
chvet73's Avatar
chvet73
Check out Doc's Blocks. They have every kind of A/C fitting. I don't think any special size was ever used.
I got parts from Docs to make custom hard lines for my new crossflow condensor. Good people.
To Please help with A/C fitting sizes
