ignition shielding help
Old Sep 1, 2009 | 09:02 PM
ahough76's Avatar
ahough76
Default ignition shielding help
I have a 69 350/350 and a pile of all the ignition shielding parts. I have no idea where things go, especially where the upper and lower shielding brackets attach to the engine. Can anyone help with pictures or diagrams as to where things go? Many thanks!!!
Old Sep 1, 2009 | 09:41 PM
GD70's Avatar
GD70
Check out the current thread "How shiney are the valve covers".
I posted some pics of valve covers & Ignition shielding from different years.
Check Vendor online catalogs. Most have the diagrams. Also Get the AIM (Assembly Instruction Manual)for your year. These were used on the assembly line by the workers.
Glenn
Old Sep 2, 2009 | 08:24 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The assembly instruction manual (AIM) shows all of it and lists the original part numbers.
Purchase the AIM; it'll be a help getting your car back together.
Old Sep 2, 2009 | 08:42 AM
GD70's Avatar
GD70
This is from the Paragon catalog. This should help.
Parts 2361 & 2262 bolt to the intake manifold using the manifold bolts.
Glenn
To ignition shielding help
