i had a long thread on this.... ended up being several problems, not just one. But the two major culprits were 1. drive shaft alignment was about 80%, and 2. flywheel was out a little, the other 20%.
I had a vibration problem that would start around 3500 rpm and get worse as the revs increased. The shifter would buzz, it would transmit through the whole car. I checked everything and couldn't find anything. Then I needed to change the water pump and discovered that the fan hub had elongated bolt holes and that the fan & fan clutch were off center causing the vibration. I would never have considered this as the source. Now no more vibration.
Good luck with this as it can be frustration to track down.
Glenn
Yea I read that whole thread....man what a pain in the as$. Im glad you got it fixed.
I will have to check those two things.
Its up in the air now so there's no turning back "jack stands scare me to death".
Think I will pull the rear all the way down and be done with it, did a fiber spring and new shocks a few years ago and should have pulled the shafts/ujoints and all the bushings back then...live and learn.
As for the water pump y-not Its old and I have nothing to loose.
Glad I have my 79 bronco to pimp when Im working on the vette, you allways need a backup classic to drive!!!
