Shock / Strutrod mount ?
Old Sep 16, 2009 | 02:17 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Default Shock / Strutrod mount ?
See the piece marked with blue tape......Before I beat on this I really need to know HOW it is suppose to come out. I am replacing the strut rods. Does it "gently slide out" or is it threaded through?
Old Sep 16, 2009 | 02:28 PM
TimAT's Avatar
TimAT
Big nut on the back comes off, install the removal tool and whack it with a big hammer. The holes in the strut are "D" shaped and have a spline that keeps the shock mount aligned correctly.
They do stick- a little rust and it's like it's welded in. I took mine out of the 69- used a big C-clamp to keep the arms from spreading, and still had to beat the thing to death. Soak the whole thing with your favorite penetrating oil. I'm also cheap- I put the nut back on with the flat side out.
I'll also state that my 69 has been driven one winter in it's life and very few times in the rain. It was stuck, but nowhere near as bad as my 77. I suspect it's going to be sawzall time for that one.
Old Sep 16, 2009 | 02:32 PM
fotyfobravo
Thanks Tim....that's what I figured. I just wanted to be sure it wasn't threaded through that mount. I am looking for my can of PB Nutbuster Spray now !
Old Sep 16, 2009 | 02:52 PM
autoist's Avatar
autoist
I used a pickle fork to get mine out.
Old Sep 16, 2009 | 03:38 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by fotyfobravo
...I am looking for my can of PB Nutbuster Spray now !...
You might want a little heat, too.
The mounts are not threaded through, but can be a real bear to get out.
Patience, Grasshopper....
Old Sep 17, 2009 | 12:15 AM
temvette72's Avatar
temvette72
If you beat on it too hard, you can bend or break the little "ears" it mounts through. I had really good luck with a two-jaw gear puller. It slid right out with minimal drama. I tried to beat on it with no luck, and that puller was a godsend.
Temvette72
Old Oct 7, 2009 | 04:10 PM
fotyfobravo
Thanks....Both sides came out without breaking anything important!
I look forward to the parts arriving so I can install new shocks and new strut rods!
Old Oct 7, 2009 | 04:19 PM
Easy Mike's Avatar
Easy Mike
...I look forward to the parts arriving so I can install the new shocks and new style strut rods...
Clean them up a little. They go back in a lot easier than they came out.
Old Oct 7, 2009 | 04:50 PM
Bronze76's Avatar
Bronze76
My Corvette Shop Manual says "reach up and pull out the shock/Strut Rod mount".
Yeah right.
It should have had a picture of Popeye with the biggest f***'n hammer ever. I wish I would have thought about the 2 jaw puller idea, that would have been better than what I did. Lucky I didn't break the ear off when I banged that sucker out of there.
Old Oct 7, 2009 | 05:11 PM
fotyfobravo
Yeah right.
Toooo Funny....That book was written before any C3s had any rust on them! Did you notice the little bottle of Nitro in the middle of my picture!
Thanks everyone.................
Old Oct 7, 2009 | 05:18 PM
TimAT's Avatar
TimAT
When I put mine back in, I coated everything with some good heavy duty anti seize. Hopefully, I'll never need to remove them again. If I do, with my luck, the anti seize will have functioned like an arc welder and I'll have to replace everything but the front bumper.
To Shock / Strutrod mount ?
