Using wire wheel to strip frame
Old Sep 17, 2009 | 10:36 AM
??????'s Avatar
Default Using wire wheel to strip frame
Just a quick question on what other people have done on there set up to wire wheel. I have wire cups normally used with low speed, or I have high speed wire wheels. Just wondering what you have used in the past. What worked, what did not ?
Thanks for the input,
Grant 77
Old Sep 17, 2009 | 10:42 AM
JimmyS5600's Avatar
JimmyS5600
Active Streak: 90 Days
I used a high speed wire wheel to clean off a frame. Then went over it with a coarse 3M pad,worked well.
Old Sep 17, 2009 | 10:51 AM
OURSHARK's Avatar
OURSHARK
I use high speed wire wheels. Larger wheels on an electric grinder and smaller wheels on a pneumatic die grinder. Just remember to ware eye protection.
Old Sep 17, 2009 | 11:51 AM
tfi racing's Avatar
tfi racing
glasses,face shield,gloves and coveralls over your clothes.Those bristles fly off and like to stick in whatever they hit,especially skin!
Old Sep 17, 2009 | 11:57 AM
autoist's Avatar
autoist
Sand blasted it!
Old Sep 17, 2009 | 12:10 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Yeah, ouch. Why wasn't I wearing my gloves? LOL.
Old Sep 17, 2009 | 12:26 PM
sheerider's Avatar
sheerider
I was wire wheeling one of my a-arms and one of the bristles came off the wheel and went through my jeans. Don't worry though my left nut stopped it!! ouch!
Old Sep 17, 2009 | 06:23 PM
Burnt71's Avatar
Burnt71
In my younger days I used a low speed wheel in a high speed grinder. In about 5 minutes most of the bristles were sticking in my arm like a porkipine
Old Sep 18, 2009 | 04:17 PM
FKING1's Avatar
FKING1
Wire wheel on a 4" angle grinder works for me. Have done many parts, but, went with sand blasting on my old pickup frame Wire brush too much work.
Old Sep 18, 2009 | 08:35 PM
markids77's Avatar
markids77
If it is undercoated I suggest blasting it. The wire wheel will just smear the Ziebart around unless you spend days washing the stuff off.
Old Sep 18, 2009 | 08:56 PM
onaqwst's Avatar
onaqwst
i would first spray wash the crap out of it...get all the grim/dirt/oil off first then wire wheel it...
use simple green and let it soak for a bit then rinse..then repeat....
go to the car wash and use that power washer if needed
Old Sep 18, 2009 | 09:13 PM
RobRace10's Avatar
RobRace10
For most of the brushing, I would use a 2-3/4" or 3-1/2" Knot Cup brush carbon steel.014 wire on a mini grinder. Your best bet is to use a USA made brush as the wire quality is much better. Only the tips cut on a wire brush and if you have to push to hard because you got a crimped wire or fine wire brush and lay the bristles over they will break very quickly as the wire fatigues.
If you can buy a Advance Brush or a Milwaukee Electric Tool as they are USA. Dewalt's are imports as are most of the ones you will find in a hardware store such as Vortec.
All that being said I sent mine out for sand blasting and powder coat and highly recommend it.
Old Sep 18, 2009 | 09:46 PM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
I happened to catch a sale at Harbor Freight on a 40 lb sandblaster for right around 100 bucks. That thing works so sweet. In fact I am doing my frame this weekend. I tried the wire wheel and it does work but takes allot more time.
Old Sep 18, 2009 | 09:52 PM
OURSHARK's Avatar
OURSHARK
To Using wire wheel to strip frame
