Modification frame 76 or 454ci 500hp!!!
Old Sep 19, 2009 | 07:05 AM
delgal's Avatar
delgal
Default Modification frame 76 or 454ci 500hp!!!
hello!!!!
my choice is made I will install an engine 454ci with 500hp!!!!!!!!
I have a corvette 76 with a L48 engine of origin.
The engine will be to replace by a 454ci
I wish to reinforce the frame!!!! how to make???
which modification I have to bring to the front cradle?????
which suspension do I have to choose?????
which triangle suspension to choose???? (C4 type)????
is it possible to put a system DANA 44???
which coil over to choose??????
coil over mounting kits???
coil over shock - QA1????
which brake rebuild kit (4) (callipers, pads & hose)
which custom engine cradle to accept 454ci engine (require coilovers)????
which rear sway bar???
which motor mount adaptor plates for 454ci????
which suspension points C4 ?????
C4 suspension, front and rear????
I thank you much if you could help me in order to carry out my dream!!!!!
David
Old Sep 19, 2009 | 08:34 AM
Ganey's Avatar
Ganey
500+ HP is not a problem.
For handling the optional FE-7 sus. will do it. If ride is an issue you could just use the FE-7 sway bars w/ std. sus. The primary advantage C4 had over C3 was the larger wheels & tires.
