Electric Choke Ground
Old Sep 22, 2009 | 12:10 AM
kortensi's Avatar
kortensi
Default Electric Choke Ground
Is there any reason that this would not be an OK way to ground the electric choke?
Thanks,
KO
Old Sep 22, 2009 | 12:54 AM
...Roger...'s Avatar
...Roger...
Looks good to me as long as there is nothing under the screw that insulates it from ground.
Old Sep 22, 2009 | 09:15 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
is that an aluminum intake or cast iron? i would be inclined to put the ground wire in the same loom that the power wire to the choke is in and ground it to a known good ground such as the alternator.
Old Sep 22, 2009 | 09:30 AM
SIXFOOTER's Avatar
SIXFOOTER
Yea, I think I would run some twin lead from the loom to the choke to keep it nice and clean. What you did will work fine, but after all the work you have done on this thing I wouldn't be running ground wires on the carb.
Old Sep 22, 2009 | 10:26 AM
Ganey's Avatar
Ganey
A short gnd. wire is a good way to do it, then one power wire hidden to disconnect to remove carb.
Old Oct 4, 2009 | 01:57 PM
Blue03Cobra's Avatar
Blue03Cobra
Where does the power wire come from, then?
Old Oct 4, 2009 | 03:01 PM
toddalin's Avatar
toddalin
Usually the ignition wire, preferably before the ballast resistor.
This way when the engine starts and runs, the coil in the choke warms up and the choke disengages. But if you sit there with the key in the accessory position (e.g., listening to the radio), you don't warm up and disengage the choke ruining it for when you are ready to actually start the car.
When I ran an electric choke, I had a switch under the dash to activate it.
Old Oct 4, 2009 | 05:17 PM
Ganey's Avatar
Ganey
You can get power from wiper motor- check for yellow wire w/ power key on.
To Electric Choke Ground
