Trailing Arm shims
Old Sep 22, 2009 | 01:17 PM
mrandig's Avatar
mrandig
Default Trailing Arm shims
On to my next question...
I recently replaced both trailing arms on my '73. I meticulously took out and measured the shims and replaced with new stainless, same thickness.
Here's my issue - the thickness of the original shims doesn't seem right - for both sides, I have .25 (inboard) x @.425 (outboard). Granted, the rear will need to be professionally adjusted/aligned; I just want to make sure that this isn't going to be a problem between now and when I eventually get the car into the shop.
"Bubba" did a lot of work on this car previously, so anything is possible, including the wrong shims. I'm finding that I need to be super-careful with the way I re-install anything I take off, as quite often wasn't right to begin with.
Does anybody have a good "starting point" for what the thickness of these shims should be?
Old Sep 22, 2009 | 01:27 PM
Mike Ward's Avatar
Mike Ward
The present shim settings don't sound unusual to me.
Old Sep 22, 2009 | 02:09 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Go with what you took out. Inner stack sets the rear. Outer stack only makes up the gap.
Alignment shop after that.
Old Sep 22, 2009 | 11:45 PM
1Fordman's Avatar
1Fordman
I just had a 4 wheel alignment done today and I put the same thickness shim packs that came out when the trailing arms were rebuilt.
The alignment tech had to move a few shims but it was fairly close.
Old Sep 23, 2009 | 02:00 AM
glen242's Avatar
glen242
When last I had my rear aligned, I took my purchased pack of SS shims to the shop. I must say they know me there and I was able to watch them do the alignment. Rear was almost done when tech says "I need a 1/32 shim". This was not included in the pack, He also mentioned that one shim size was not correct as to the size marked.
Called the supplier of the shims, well known Corvette supplier, and told him. He went into his stock, and sure enough, shims were not the same size as marked. They did/do not have anye 1/32" shims.
Went to my friend who makes a living rebuilding Corvette rear ends, and he had a couple of GM 1/32" shims.
Back to the shop and got a dead nuts on rear alignment.
To Trailing Arm shims
