I have replaced the radiator, water pump and thermostat. When I am on the highway in fourth gear, the car run's hot. When I downshift, the temperature drops a little. I still think it is running way too hot at 220 degrees. Any suggestions? Thanks
Switch to a 180 degree thermostat, and make sure you have the add on spoiler installed under the front....its critical for proper cooling.
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
I was thinking a 160 degree thermostat.
My '75's been running around 200 lately. Usually stays around 180. Have had some carb issues that has made me have to throttle the gas pedal in order for it to stay running at a stop. Have the carb dialed in to where it idles smoother and at a proper RPM. Now all I have to do is wait for the skies to clear.
Be careful not to run it too cool, vac switches still need temp to properly function.
Also if you run with a 160 thermostat, you run the risk of it staying open continuously, actually causing your car to overheat.
In extreem conditions all the water in a factory rad system can get too hot.
A 185 thermostat running at 200 degrees is actually close to ideal.
If you have a 160 degree thermostat and you are running 200 degrees ya might want to look for the real problem and change back to a 180.
JMHO
Exactly the question i wanted to ask about my 75 running hot also.
I have on order a 180degree thermo to be installed, and also have a new aluminum 3 row radiator to be isntalled as well with dual electric fans.
The car is missing the radiator fan shrouds since the stock fan is removed, but I will fabricate something for it hear the top.
As for the bottom, toolman1981, you mentioned front under spoilers? So should I not make the lower shroud piece and instead make a sort of "scoop" similar to the C5 radiator lower air scoop spoiler?
This overheating is pretty much the only thing keeping me from driving the car. =/
PS my water pump is new from what the previous owner had said when motor was rebuilt. Other than that, I am guessing I have the same problem as jskenter
check the timing, make sure it isn't running lean, the lower chin spoiler is a must, make sure the guage is actually reading correctly, and the radiator seals will help some too
JMHO
Good advise.
I got my '75 out today. Still hitting 200-205. Beginning to think the thermostat might be trying to stick.
Might try another 180 thermostat and see what happens.
