"T" handle on Hurst Shifter
Old Sep 24, 2009 | 02:00 PM
DIP51's Avatar
DIP51
2018 C2 of Year Winner
Default "T" handle on Hurst Shifter
Does anyone know if the reverse lockout T handle from a Hurst shifter is the same as the stock shifter? I have a Hurst for sale and I can't find the effin T handle!!!
If they are the same, I guess I would be looking for one to complete the shifter I have. I willl begin rummaging thru my garage tonight in search of it. It HAS to be somewhere, but why it isn't still in the shifter?!?!?
Old Sep 24, 2009 | 02:04 PM
GD70's Avatar
GD70
Not on mine. The lock out lever on the steering column is wired in the unlocked position.
Old Sep 24, 2009 | 03:55 PM
DIP51's Avatar
DIP51
No, not the steering wheel lockout lever...that was functional on the steering column. I am talking about the T handle for the shift lever that you have to lift to get the trans in reverse.
The shifter is a Hurst Comp Plus that replicates the original shifter design, not the classic flat bar Hurst handle.
Old Sep 24, 2009 | 04:44 PM
GD70's Avatar
GD70
The hurst shift lever does not have the "T" lever to lift for reverse. It just shifts into reverse, but you really have to push it hard to do so. It's designed that way so you don't accidentally hit reverse when down shifting from 2nd to 1st. I hope this helps answers your question.
Glenn
Old Sep 24, 2009 | 04:53 PM
The13Bats's Avatar
The13Bats
Glenn, you are correct about the kid racer Hurst flat stock shifter he is talking about this item,
If I recall it's a pretty close copy of the orginal, the "T' might swap out,
Old Sep 24, 2009 | 07:16 PM
DIP51's Avatar
DIP51
Yup, that's the baby!!! I need to know if the stock T works???
Old Sep 24, 2009 | 07:56 PM
GD70's Avatar
GD70
Nope. For looks only.
Old Sep 24, 2009 | 08:16 PM
CCrane65's Avatar
CCrane65
The "T" is shorter than the stock one and has plastic bushing around it where it slides down into the stick. You can't use a factory "T" handle on it.
cc
Old Sep 24, 2009 | 09:10 PM
The13Bats's Avatar
The13Bats
cc
So it IS real and not just for looks?
Old Sep 24, 2009 | 09:26 PM
DZRick's Avatar
DZRick
Nope
http://www.ecklers.com/product.asp?p...6&dept_id=1888
Get stock looks with Hurst performance using our Custom Shifter Handle. This triple chrome plated handle and ball bolts to all 1964-81 Hurst Shifters and even retains the stock look with a non-functional reverse lockout.
Old Sep 24, 2009 | 09:30 PM
The13Bats's Avatar
The13Bats
Then I wonder what the heck I took off my 66, it wasnt stock, the linkage parts were Hurst, it "looked" like that stock copy shifter but had a working "T" but didn't 100% match a stock shifter,
Old Sep 24, 2009 | 09:46 PM
DZRick's Avatar
DZRick
Interesting, I wonder if they can be modified to work, but then I'd be curious as to why Hurst wouldn't have made the piece functional.
Old Sep 24, 2009 | 09:54 PM
The13Bats's Avatar
The13Bats
I swapped it out of my 66 installed a flat stock shifter so I could run the ball I wanted and....Ahem, at the time 10 plus years ago I liked the racy look of the Hurst stick,
I will go see if I can find a picture of the stock vette shifter to see if it rings a bell how mine was different, of course a PO might have modded mine,
Old Sep 24, 2009 | 11:43 PM
rajsid's Avatar
rajsid
Just for looks.
The Hurst handle will not fit on a stock linkage.
You need a hurst linkage installed on your car to use that handle.
Old Sep 25, 2009 | 01:40 AM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
Originally Posted by rajsid
Just for looks.
The "T" lever is just for looks
Old Sep 25, 2009 | 08:48 AM
CCrane65's Avatar
CCrane65
The Hurst "T" does pull up and has a spring on top like the factory shifter, it just doesn't do anything functional.
The factory shifter "T" handle has a rod that goes all the way through the shift lever into the shifter to block access to reverse unless it is pulled up.
cc
Old Sep 25, 2009 | 08:52 AM
CCrane65's Avatar
CCrane65
The factory shifter is not spring loaded requiring some form of positive lockout. You will notice that the shifter wobbles from side to side in neutral. Without the lockout it would go all the way over to the left allowing accidental reverse engagement.
The Hurst is spring loaded and requires some positive effort to move it into reverse. It also does not wobble in neutral.
All non-internal rail Hurst shifters use a 2 bolt system to secure the handle to the shifter. That would make it difficult to run a rod through the center of the lever to be functional like the factory shifter. Besides, the Hurst shifter does not have anything for a lockout rod to bump up against to keep you from engaging reverse.
cc
Old Sep 25, 2009 | 09:07 AM
The13Bats's Avatar
The13Bats
cc
Right on!
I was bugged that I couldn't remember it,
I called dad and at 83 he recalled it well,
He says just that the "T" was spring loaded but fake, didn't really unlock anything, and all the shifter parts were Hurst....
Old Sep 25, 2009 | 11:41 AM
DIP51's Avatar
DIP51
cc
Thanks guys. All that time I was lifting the T to engage reverse!!! I never gave it any thought, I just always did it, because I was used to doing it in previous cars. I guess you learn something new everyday. If it were still in the car I would still be lifting it!!!
To "T" handle on Hurst Shifter
