Oh great... Help please
Old Sep 29, 2009 | 10:09 AM
VetteGuy82's Avatar
VetteGuy82
Default Oh great... Help please
Finally figured out my fuel issue (had the fuel pump wired wrong) and finally started my 82 after 12 years of sitting. Thats the good news. The bad news is theres a hard metal on metal knocking sound coming from the engine bay. Any ideas what this could be? MY friend (who is a licensed mechanic) says he think its coming from the lower engine or tranny. Thanks.
Old Sep 29, 2009 | 10:15 AM
moosie982's Avatar
moosie982
One thing could be a loose torque converter/flex plate bolt(s), probably lots more possibilities but I'd check that. Good Luck, Peace,,,Moosie
Old Sep 29, 2009 | 10:57 AM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
Does it have a solid knocking sound(than it could be a Lifter not pumping up) Or a hollow knocking sound(Rod or Main bearing is bad)
A quick way to check if the torque converter/flex plate bolts are loose is to start the car and put it in gear,than put a slight load on the drive train.. hold the brake and bring the RPM's up between 1200 to 1500 and see if the knocking goes away.
Do you know for sure that the car had no knocking 12 years ago? Hows your oil pressure?
Old Sep 29, 2009 | 11:16 AM
gerry72's Avatar
gerry72
If your friend thinks it may be a rod knock, then with the engine at idle, pull one spark plug lead at a time. If you have a rod knock, pulling power off the cylinder will kill or greatly reduce the knock. If a bunch of rods are knocking, it may be hard to notice a significant change.
Obviously you'd want to try to detect the location of the knock and do a visual inspection first.
Old Sep 29, 2009 | 11:30 AM
VetteGuy82's Avatar
VetteGuy82
well all i know is a. is was really loud b. it was coming from the rear of the engine or the front of the tranny
VetteGuy82's Avatar
VetteGuy82
oil pressure seemed ok
Old Sep 29, 2009 | 06:32 PM
jdp6000's Avatar
jdp6000
Just a guess but is the starter staying engaged?
Jim
Old Sep 29, 2009 | 10:14 PM
MN-Brent's Avatar
MN-Brent
Rod knock would be my guess.
What did you do for oiling before you started it?
Old Sep 29, 2009 | 11:03 PM
Goody's Avatar
Goody
Old Sep 29, 2009 | 11:07 PM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
as soon as you said lower engine, That is most likely a rod knock.
To Oh great... Help please
